Hızlı Arama
Ürün Özellikleri:
External Fixed Dome Full HD IP-camera
Genel Özellikler:
Fiziksel Özellikler
The exceptional quality of the video
• 1/2 inch, 8-megapixel CMOS-sensor with progressive scan
• Full HD resolution of 1920 x 1080
• WDR technology provides improved image quality
• codec support H.264, MPEG-4, MJPEG for streaming and recording
• Motion detection
• Private masks
Outdoor installation
• Built-in IR LEDs (15 m) for video surveillance in the dark
• A number of options for mounting the camera
• Rugged weatherproof casing (standard IP-68)
• Weather protection shield to protect the unit for outdoor installation
Flexibility
• Card slot MicroSD / SDHC
• Port 10/100 Fast Ethernet with support for PoE, providing easy integration into network
• Digital inputs and outputs for connecting external devices
• The audio input and audio output to connect a microphone and speaker for two-way audio transmission
Hardware profile camera
• The distance infrared illumination: 15 m
• Minimum illumination: 0.2 Lux / F1.4 (Color)
• Minimum illumination: 0.05 lux / F1.4 (B & W)
• Minimum illumination: 0 lux (black-and-white mode with infrared illumination)
• Removable ICR-filter
• Varifocal lens: 2.8 mm to 12 mm
• The aperture of F1.4
• The minimum object distance of 0.2 m (width 2.8 mm)
• Viewing angle (16:9):
  96.5 °  ~ 31.2 °  (horizontal)
  + 64.5 °  ~ 17.8 °  (vertical)
  + 117.5 °  ~ 36.8 °  (diagonal)
• Adjustable in three axes:
  + 340 °  (rotation)
  + 75 °  (tilt)
  + 300 °  (rotation)
The camera body
• Weatherproof (standard IP-68) and anti-vandal (standard IK-10) body
• Weather protection hood
Image characteristics
• Setting the image size and quality, frame rate and bit rate
• The timings and paste text
• Customizable windows for motion detection
• Customizable zone private masks
• Set the exposure time, brightness, color saturation, contrast and sharpness
Video Compression
• Compression formats H.264/MPEG-4/MJPEG
• H.264/MPEG-4 multicast broadcasting
• JPEG for still images
Video Resolution
• 16:9 - 1920 x 1080, 1280 x 720, 800 x 450, 640 x 360, 480 x 270, 320 x 176, 176 x 144 and 30 frames / s
• 4:3 - 1440 x 1080, 1024 x 768, 800 x 600, 640 x 480, 320 x 240, 176 x 144 and 30 frames / s
Audio Support
• G.726
• G.711
Interfaces to external devices
• Port 10/100 BASE-TX Fast Ethernet with PoE
• 1 DI / 1 DO
• Output voltage: 12 V DC, 100 mA
• Audio In / Audio Out
Network Protocols
• IPv6
• IPv4
• TCP / IP
• UDP
• ICMP
• DHCP-Client
• NTP-Client (D-Link)
• DNS-client
• DDNS-Client (D-Link)
• SMTP-client
• FTP-client
• HTTP / HTTPS
• Samba-client
• PPPoE
• UPnP port forwarding
• RTP / RTSP / RTCP
• Filtering IP-addresses
• QoS
• CoS
• Multicast
• ONVIF
Safety
• Security administrator account and user groups
• Password authentication
• Encryption HTTP and RTSP
System requirements for Web-based interface
Web-browser: Internet Explorer, Firefox, Safari, Chrome
Event Management
• Motion detection
• Event notification and download stop-kadrov/videoklipov via email or FTP
• Support for multiple SMTP servers, and FTP
• Multiple event notifications
• Several ways to create backups
Remote management
• Create stop-kadrov/videoklipov and save to a local hard drive or NAS via Web-browser
• Interface settings, available through the Web-browser
Remote management
OS Support
Windows 8, 7, Vista, 2000 or XP
System Requirements D-ViewCam ™
• Operating System: Microsoft Windows 8/7/Vista/XP
• Web-browser: Internet Explorer 7 or above
• Protocol: Standard TCP / IP
The software features D-ViewCam ™
• Remote management / control of up to 32 cameras
• Viewing images on a single screen: up to 32 cameras
• Recording Options for triggering a sensor or manually
• Supports all management functions available through the Web-based interface
Fiziksel Özellikler
Weight
1,112 kg
Nutrition
• Input: 100-240 VAC, 50/60 Hz
• Output: 12V DC, 1.5A
Power consumption
10W ± 5%
Temperature
• Operating: -30 °  to 50 °  C
• Storage: -20 °  to 70 °  C
Humidity
• Operating: 20% to 80% (non-condensing)
• Storage: 5% to 95% (non-condensing)
Certifications
• CE
• CE LVD
• FCC
• C-Tick
Measurements
Ürünler | Destek  | Haberler  | Hakkında |
