Hızlı Arama
Ürün Özellikleri:
HD Wireless N Mini Dome Network Camera
Yeni
Tanımlama:
Tanımlama:
The DCS-6005L HD Wireless N Mini Dome Network Camera is a mydlink-enabled IP surveillance camera built with a ultra small form factor and features wireless N connectivity, making it ideal for monitoring areas that are hard to reach or require discrete surveillance.
Built for Versatility
The DCS-6005L comes with a wealth of features that enhance its surveillance capabilities, making it ideal for any situation. The ultra small form factor allows you to mount the camera in areas that need to be monitored without the camera being an eyesore. Meanwhile, the DCS-6005L comes with built-in wireless N capability, making it ideal for deployment into areas that are not directly connected to your existing wired network. A built-in microphone and audio out allow for 2-way communication during an event.
Peace Of Mind With 24/7 Monitoring of Any Environment
The DCS-6005L is a standalone surveillance camera that requires no special hardware or software, and can run independently even without a PC. Send e-mail notifications with snapshots or video clips whenever motion or sound is detected using just the DCS-6005L and an internet connection. You can customize areas of the video to monitor for motion to keep watch over entryways, and you can set volume limits to detect when a loud sound is picked up by the camera. Night time monitoring is possible with the built-in infrared LEDs which allow for nighttime viewing of up to 16 feet (5 meters), enabling round-the-clock monitoring of a home or small office.
Instant Anywhere Access with mydlink Cloud Service
The HD Wireless N Mini Dome Network Camera is mydlink-enabled, which means that you can access and configure your camera remotely, no matter where you are. With a mydlink service enabled camera, see your camera’s live view through the mydlink website, or download the mydlink mobile app and view your camera directly on your smarthphone or tablet. Keep an eye on your home while you’re at work, or check on the office when you’re out on the road; mydlink makes it all possible.
A Complete, Expandable Surveillance Solution
The DCS-6005L is a self-sufficient surveillance solution, capable of recording snapshots and video to a MicroSD card without requiring a PC or network storage device.
If you want to expand your surveillance options, D-ViewCam management software is also included, giving you the ability to manage up to 32 cameras with a robust set of features, including multi-camera views and automated e-mail alerts to keep you informed of suspicious or unusual activities.
Ürünler | Destek  | Haberler  | Hakkında |
