DCS-2210L/UPAEOL EOS
HD Cube Network Camera
Tanımlama
Continuous Monitoring
DCS-2210/2230 cameras - is a versatile solution for small offices and homes in low-light conditions. The camera has a 2 million.pixels for high-resolution sensor and an integrated infrared illuminated so it can carry out surveillance of the premises in total darkness. DCS-2210/2230 also has built-in ICR filter, so they can be used in both diurnal and nocturnal observation. In addition, this camera is a complete system with a built-in CPU and web server that transmits high quality video. DCS-2210 supports PoE power supply, so it can be installed in places where there are no electrical outlets. DCS-2230 supports 802.11n wireless standard, so it can be mounted anywhere within range of your wireless network. Cameras easy to install, they have an intuitive Web user interface that supports remote control and motion detection features. DCS-2210/2230 - is kompeksinis, cost-effective home and office security solution.
ePTZ function
ePTZ function allows you to select the desired tracking / shooting areas to increase the use of the web browser. Because of these features 2 million. pixel resolution camera to deliver sharp color images and can monitor a large area. The fact that the camera has no moving parts, only increases its reliability.
Easy installation and use
DCS-2210/2230 fully compliant with the Universal Plug-n-Play standard that allows a computer with Windows XP/Vista/7 to automatically detect the camera and connect it to your network. Using one of the many free Dynamic DNS services online, the camera can assign an easy to remember domain name (for example, mycamera.dlinkddns.com). In this way, remote access to the camera, even without knowing its IP address. Software D-Link D-ViewCam allows simultaneously on a single computer screen shows 32 cameras view. The camera can be set for automatic e-mail alert about unusual events in the system.
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DCS-2210L/UPA/Ax
Back view
Left side view
Front view
İndir
Destek Merkezi
