Hızlı Arama
Ürün Özellikleri:
HD Outdoor Mini Bullet Camera
The D-Link DCS-4701E Vigilance HD Outdoor PoE Mini Bullet Camera is a high-definition
professional surveillance and security solution suitable for small, medium, and large enterprises.
The camera uses a high-sensitivity 1.3 megapixel progressive scan CMOS sensor to deliver truly
superior quality video under a wide range of lighting conditions. The all-in-one rugged design
makes this camera ideal for reliable deployment in surveillance applications without the need
for additional accessories.
Enhanced LowLight+ Video
Incorporating a highly sensitive CMOS sensor, the DCS-4701E provides outstanding
performance in low-light conditions, rendering more vibrant color details regardless of the
amount of light available. The noise reduction feature has also been upgraded and enhanced
as well to provide a level of detail in the image quality that is unmatched by other offerings in
the market.
Continuous Monitoring
The built-in IR LED illuminators automatically turn on depending on lighting conditions,
allowing the camera to capture video even in low-light or no-light conditions. Combined with
the IR-Cut filter, the DCS-4701E can also provide sharp grayscale video in low-light conditions.
Embedded with a powerful SoC (System-on-Chip), the camera provides real-time video
compression in H.264 and MJPEG formats. These elements combine to make the DCS-4701E an
ideal solution for 24-hour surveillance.
Convenient Connectivity
The DCS-4701E has a built-in 802.3af compliant PoE module that eases installation by providing
power and networking connectivity with a single cable, reducing the need to drill holes or lay
additional cablin
Ürünler | Destek  | Haberler  | Hakkında |
