DUB-1342EOL EOS
3-port ultra-fast USB 3.0 Hub with card reader
Tanımlama
High-speed USB 3.0 interface
Connect the device to a USB 3.0 hub and get the speed up to 5 Gbit / s - 10 times the speed interface USB 2.0. It is now possible to back up your photos, music and HD movies on an external storage device faster than ever before. DUB-1342 is ideal for connecting external storage devices to the computer.
The ability to connect other devices
Backward compatible with USB 2.0 and USB 1.1 allows you to connect any USB-device to the DUB-1342. Three USB-ports can simultaneously connect up to three USB-devices. If you need more ports, you can connect an optional USB hub that allows you to connect up to 127 devices.
The transfer of data from mobile devices
Five card reader slots allow you to transfer data such as music, photos and data from mobile devices to a computer at a rate of up to 480 Mbit / s. Supported card types: CF, MD, MS, SD, MMC and microSD. In addition, you can use additional types of cards: miniSD, miniSDHC, MMCmobile, MMCmicro, RS MMC and Memory Stick Micro (M2). Card reader for smart card provides access to a computer without entering the password, and allows you to keep safe the user data during online shopping or banking operations.
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DUB-1342/Ax
Back view
Front view
İndir
Destek Merkezi
