Hızlı Arama
Ürün Özellikleri:
5dBi Omni-Directional Antenna
Genel Özellikler:
Frequency Range
2.4GHz to 2.5GHz
Peak Gain
5dBi (typical)
HPBW/Horizontal
360
Impedance
50 ohm (normal)
Admitted Power
2 watt
VSWR
2.0 : 1 (max.)
HPBW/Vertical
40
Fiziksel Özellikler
Color
Black
Connector
Reverse SMA plug (built into antenna)
Antenna Material
ABS, UV resistant
Temperature
-10 to 55C
Humidity
95% at 55C
Dimensions
13.5 x 188 mm
Weight
20 grams
Ürünler | Destek  | Haberler  | Hakkında |
