DCS-2230EOL EOS
Network 802.11n wireless two-megapixel IP-camera «Cube» with support for Full HD and H.264
Tanımlama
Round the clock surveillance
Network Camera «Cube» with support for Full HD DCS-2210/2230 - stop solution for video surveillance at home and small office use in low light conditions. Thanks to high-resolution two-megapixel sensor and built-in IR illumination, can be observed in the room, even in complete darkness. DCS-2210/2230 also has a built-in ICR-filter, which makes the camera suitable for day and for night use. Moreover, DCS-2210/2230 is a turnkey solution with built-in CPU and web-server that transmits high quality video images for security and surveillance. DCS-2210 supports Power over Ethernet (PoE), so that the camera can be placed in areas where power outlets are not available. DCS-2230 with 802.11n can be placed anywhere within the wireless network. DCS-2210/2230 also offers easy installation, intuitive web-based interface supports remote control and motion detection features for a complete and cost-effective solutions to ensure security at home and in the office.
802.11n wireless connectivity
DCS-2230 supports wireless interface 802.11n, providing quick and easy integration into an existing network. Wireless N technology allows for streaming high-quality video to remote sites or mobile devices. Site Survey feature also allows you to easily view and connect to nearby wireless networks. DCS-2103/2130 camera is equipped with an Ethernet port for connecting to a standard wired networks.
Functions ePTZ
EPTZ functions to select the desired area to view in an enlarged scale by clicking an icon in the video browser. Thanks to ePTZ megapixel camera with a resolution delivers sharp images and surveillance of large areas with little effort. No moving parts means the operational reliability of the camera.
Easy setup and easy to use
The network camera supports Plug-n-Play, which allows computers running on Windows XP/Vista/7 to automatically recognize the camera and add it to the network. Sign up with one of the free servers DDNS, you can set the camera domain name (for example, mycamera.dlinkddns.com). This will allow the use of remote access to the camera without knowing its IP-address.Software D-ViewCam D-Link allows you to view up to 32 cameras on a single computer screen. Users can set up an automatic notification by e-mail to be instantly informed of unusual activities.
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DCS-2230/Ax
Back view
View from the right
Front view
İndir
Destek Merkezi
