Hızlı Arama
Ürün Özellikleri:
The omni-directional antenna for indoor use, 8 dBi
Genel Özellikler:
Fiziksel Özellikler
Resistance
50Ω
Directionality
Omnidirectional
VSWR
2.0 (max)
The maximum gain
8dBi (lossless cable)
Allowable Power
1 W
Reflectivity
-10 DB (maximum)
Antenna Type
Collinear antenna
The diagram in the horizontal plane (vector H)
360 °
Radiation pattern in the vertical plane (vector E)
24 °
Fiziksel Özellikler
Jack
RP-SMA
Operating temperature
-10 ° C ~ +45 ° C
Storage temperature
-20 ° C ~ +70 ° C
Operating Humidity
From 5% to 95% (non-condensing)
Humidity
The color and material of the antenna
•  Antenna: Black
•  Base plate: black
•  Material: ABS, ABS + PC
Certifications
RoHS
Weight
35 grams
Measurements
325 x 13 mm
Ürünler | Destek  | Haberler  | Hakkında |
