Hızlı Arama
Ürün Özellikleri:
Triple 2.4 GHz omnidirectional antenna, 2dBi
Tanımlama:
Optimal Performance
Triple 2.4 GHz omnidirectional antenna D-Link ANT24-0230 - is a universal antenna, designed to improve the performance of your adapter Xtreme N (DWA-552) and Router (DIR-655) from the company D-Link, as well as the RangeBooster N 650 Adapter (DWA- 547) and Router (DIR-635) from the company D-Link.
Indoor Installation
Triple 2.4 GHz omnidirectional antenna D-Link ANT24-0230 comes with an extension cable that allows you to place the antenna close to the adapter and the router. Thus, it is possible to have a functioning wireless network by placing a desktop computer under the table, and the antenna ANT24-0230 - on the table, or attach it to the wall. You might also consider the location of the router in a closet or a confined space in which you can still achieve optimal wireless coverage by using a triple 2.4 GHz omnidirectional antenna.
Installation flexibility and increased productivity
Triple 2.4 GHz omnidirectional antenna D-Link ANT24-0230 increases the flexibility of the plant for the adapter and the router, allowing you to increase network capacity.
Ürünler | Destek  | Haberler  | Hakkında |
