Ürün Özellikleri:
Wireless N300 wireless repeater to increase the coverage area |
Genel Özellikler:
Fiziksel Özellikler
Device Interfaces
• 802.11 n / g / b
• WPS Button
• The Reset button
Indicators
Status / WPS
Standards
IEEE 802.11b/g/n
Data rate
• IEEE 802.11b: 11, 5.5, 2 and 1 Mbit / s
• IEEE 802.11g: 54, 48, 36, 24, 18, 12, 9 and 6 Mbit / s
• IEEE 802.11n *:
Unit: Mbit / s
The output power of the transmitter
• IEEE 802.11b:
20 dBm at 1, 2, 5,5, 11 Mbit / s
• IEEE 802.11g:
20 dBm at 6-36 Mbit / s
19 dBm at 48 Mbit / s
18 dBm at 54 Mbit / s
• IEEE 802.11n:
HT20:
20 dBm at MCS0-MCS4 and MCS8-MCS12
19 dBm at MCS5 and MCS13
18 dBm at MCS6-MCS7 and MCS14-MCS15
HT40:
19 dBm at MCS0-MCS5 and MCS8-MCS13
18 dBm at MCS6 and MCS14
17 dBm at MCS7 and MCS15
Receiver Sensitivity
• IEEE 802.11b:
-87 DBm at 1 Mbit / s
-87 DBm at 2 Mbit / s
-85 DBm at 5.5 Mbit / s
-82 DBm at 11 Mbit / s
• IEEE 802.11g:
-82 DBm at 6 Mbit / s
-81 DBm at 9 Mbits / s
-79 DBm at 12 Mbit / s
-77 DBm at 18 Mbit / s
-74 DBm at 24 Mbit / s
-70 DBm at 36 Mbit / s
-66 DBm at 48 Mbit / s
-65 DBm at 54 Mbit / s
• IEEE 802.11n:
20 MHz
-82 DBm at MCS-0/8
-79 DBm for MCS-9/1
-77 DBm at MCS-2/10
-74 DBm at MCS-3/11
-70 DBm at MCS-4/12
-66 DBm at MCS-5/13
-65 DBm at MCS-6/14
-64 DBm at MCS-7/15
40 MHz
-79 DBm at MCS-0/8
-76 DBm for MCS-9/1
-74 DBm at MCS-2/10
-74 DBm at MCS-3/11
-67 DBm at MCS-4/12
-63 DBm at MCS-5/13
-62 DBm at MCS-6/14
-61 DBm at MCS-7/15
Frequency range
From 2.4 GHz to 2.4835 GHz
Antennas
Two internal antennas
Plug
Varies by region
Safety
• Wi-Fi Protected Access (WPA and WPA2)
• 64/128-bit WEP-encryption
• WPS (PBC)
Advanced Features
Application Support QRS (iOS, Android)
Management
Web-based interface
Measurements
48 x 42 x 53.5 mm
Weight
69 g
Nutrition
From 110 to 240 VAC, 50/60 Hz
Temperature
• Operating: 0 ° to 40 ° C
• Storage: -20 ° to 65 ° C
Humidity
• Operating: 10% to 90% (non-condensing)
• Storage: 5% to 95% (non-condensing)
Certifications
• FCC
• IC
• CE
• UL
• EMI / EMC
• Wi-Fi
• C-Tick
* The maximum data rate over the air to determine the technical requirements of the 802.11g and IEEE 802.11n. Actual data throughput will vary. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, building materials and construction, and network overhead transmission can reduce throughput. Environmental factors also adversely affect the strength of the wireless signal.
Destek Merkezi
