DWA-137EOL EOS
Wireless 802.11n USB-adapter with high gain
Tanımlama
Wireless USB-Adapter DWA-137 allows you to connect your computer to a high-speed wireless networks and provides excellent reception. When the connection is established, you can access high speed Internet connection and start viewing Web-pages, streaming video and music, as well as play online games and share common access to the content for friends.
High performance
Adapter DWA-137 delivers high performance wireless connectivity for your computer. Users can easily add a network adapter, and view Web-page, to provide shared access to files and printers, and chatting. High speed wireless connectivity extends the use of the Internet, ensuring efficient services, bandwidth intensive, such as IP-telephony, online gaming, and video streaming.
Extended range
Adapter DWA-137 provides the ability to use wireless connectivity in remote places. Antenna with high gain, which is equipped with an adapter, improves the quality of signal reception. Therefore, using DWA-137 can connect to a wireless network at greater distances from the router or access point, than a conventional wireless adapter. The possibility of rotation of the antenna allows to eliminate low-band signal and improve reception quality by means of precise adjustment of the antenna in space. Maximize wireless performance by connecting to a wireless router 802.11n, and use a network connection anywhere in your home.
Easy to install and use
Setup Wizard D-Link makes it easy to install USB-adapter. Technology Wi-Fi Protected Setup (WPS) provides a secure wireless connection, without requiring the user complicated settings. With this technology does not require complicated set manually encryption codes; just click the button to connect the device to the network and configure security. Backward compatible with the 802.11g standard can be used in wireless networks with outdated equipment.
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DWA-137/A1
Front view
View from the right
İndir
Destek Merkezi
