Hızlı Arama
Ürün Özellikleri:
Dual-band (2,4/5GHz) 802.11n kablosuz USB adaptör, 300 Mbit/s
Tanımlama:
Wireless dual-band (2.4/5 GHz) wireless USB adapter DWA-160 enables a reliable wireless connection to a public wireless network ("hotspot") or dvuhdiapazonnomu router, which can be used for streaming high-definition video (HD). USB adapter DWA-160 enables you to connect your computer to a high-speed wireless network and provides excellent signal reception. Once connected, you can get access to high-speed Internet connection, as well as the total secure access to your photos, files, music, video, printers, and storage.
Use two frequency bands
USB adapter DWA-160 supports dual-band 2.4 Ghz range this can be used to check e-mail and access the Internet through a wireless network in the 5 Ghz frequency range it is possible to transfer an HD streaming video and other media content.
Increased speed and expanded the range of network
Dual band USB adapter DWA-160 Xtreme N provides a connection to the wireless network at a faster speed and at a greater distance than the previous 802.11 standards adapters. This ensures quick and reliable connection anywhere in your home.
Easy installation and use
Installation Wizard provides step-by-step instructions that you can use to quickly and easily connect to a wireless network, even in the absence of experience with networks. Due to its high performance, reception and security, this adapter is the best choice for wireless connection of desktop computers.
Ürünler | Destek  | Haberler  | Hakkında |
