Hızlı Arama
Ürün Özellikleri:
64 AP lisansı ile Unified Wireless Controller 4 10/100/1000 + 4 combo 100/1000 SFP
Genel Özellikler:
Interface
Ports
4 x 10/100/1000 RJ-45 and 4 x 100/1000 SFP Combo ports
2 x USB 2.0 ports
Console Port x 1 RJ-45
Extension Slot x 1 Hard disk driver slot
Performance
Maximum Access Points per Unit
64/ 2561 (default/ upgrade)
Maximum Access Points per Cluster
256/ 10241 (default/ upgrade)
Concurrent Captive Portal Authentication Users
6300
Access Point Management
Model of Managed APs
DWL-8610AP
DWL-8600AP
DWL-6600AP
DWL-3600AP
DWL-2600AP
AP Discovery & Control
Layer-2
Layer-3
AP Monitoring
Managed AP
Rogue AP
Authentication Fail AP
Standalone AP
Client Monitoring
Authenticated Client
Rogue Client
Authentication Fail Client
Ad-hoc Client
Centralized RF/ Security Policy Management
Roaming
Intra-controller
Inter-controller Roaming Intra-subnet
Inter-subnet Roaming
Fast Roaming
Mobility
Layer 2 / Layer 3 Roaming
Security
Wireless Security
WEP
Dynamic WEP
WPA Personal/Enterprise
802.11i WPA2 Personal/Enterprise
EAP-MD5, EAP-TLS, EAP-TTLS, EAP-FAST, EAP-SIM, PEAP-GTC
WPA Ciphers - TKIP - CCMP (AES) - TKIP and CCMP (AES)
Wireless Intrusion Detection & Prevention System (WIDS)
Rogue and Valid AP Classification
Rogue AP Mitigation
LAN Security
802.1x port-based access control
Guest VLAN
Authentication
Captive Portal
MAC Authentication
VLAN
VLAN Group (Up to 255 entries)
802.1q VLAN Tagging
Subnet-based VLAN
Port-based VLAN
IP Mode
IPv4 / IPv6 mode
DHCP
Server
Relay
Client
Quality of Service (QoS)
Wireless Multimedia (WMM)
Spectralink Voice Priority (SVP)
SIP
H.323
QoS Policy
CoS
ToS
DSCP
AP firmware management
AP firmware version auto-detection and dispatch
Bandwidth Management
Minimum Bandwidth Guarantee
Bandwidth Control
Layer 2 Multicast
User Account Management
Permanent Account Authentication Method
Local Database
External RADIUS
External LDAP
External POP3 External Windows Active Directory (wired only)
Temporary Account Authentication Method
Local Database
Temporary Account Creation
Single or batch account generation by system with customized active or usage expired time
Payment Gateway
Authorize.net
Paypal
SecurePay
World Pay
Management
SSH(v2)
HTTP/HTTPS
Web-based User Interface
Command Line Interface
SNMP v1, v2c, v3
TFTP
802.11h spectrum and Transmit Power Management
802.11d Country Code
AP Load Balancing Utilization
Fiziksel Özellikler
Power Supply
100-240 V AC, 50-60 Hz Internal power supply
Max. Power Consumption
26.95 W
Dimensions
440 x 310 x 44 mm (17.3 x 12.2 x 1.73 inches)
Operating Temperature
0 to 40 °C (32 to 104 °F)
Storage Temperature
-20 to 70 °C (-4 to 158 °F)
Operating Humidity
5% to 95%, Non-condensing
Emission (EMI)
FCC Class A
CE Class A
C-Tick, IC
Safety
cUL
LVD (EN60950-1)
Diagnostic
Capture Packets
System Check
Network Tools
Ürünler | Destek  | Haberler  | Hakkında |
