Hızlı Arama
Ürün Özellikleri:
Dual-Band 802.11n/ac Unified Wireless Access Point
Genel Özellikler:
Fiziksel Özellikler
Hardware
Interfaces
• 802.11b / g / n 2,4 GHz
• 802.11a / n / ac 5GHz
• One LAN port 10/100 / 1000Base-T with support for PoE 802.3at
• Console port with RJ-45
Indicators
• Food
• LAN
• 2.4 GHz
• 5 GHz
Buttons
• Reset to the factory settings
• Power button
Antenna • Internal omnidirectional antenna with 5 dBi for 5 GHz and 3,5 dBi for 2.4 GHz
Scheme MIMO • 2x2
Housing
• The bottom panel - plastic
• Top panel - plastic
• Certification UL2043 (for housing class "plenum")
Power connector • Power connector (DC)
The parameters of the wireless module
Standards • IEEE 802.11a / b / g / n / ac
Frequency Range
• 802.11b / g / n: from 2.4 GHz to 2.4835 GHz
• 802.11a / n / ac: 5.15 GHz to 5.35 GHz
Wireless Security
• Up to 32 SSID, SSID 16 in the radio band
• 802.1Q VLAN
• Clients Isolation
• WPA / WPA2 - Personal / Enterprise
• AES and TKIP
• Filtering by MAC-address-
• Detect unauthorized access points
Wireless speed
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit / s
• IEEE 802.11b: 1, 2, 5.5 and 11 Mbit / s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit / s
• IEEE 802.11n:
MCS GI = 800ns GI = 400ns
  20 MHz 40 MHz 20 MHz 40 MHz
0 6.5 13.5 7.2 15
1 13 27 14.4 thirty
2 19.5 40.5 21.7 45
3 26 54 28.9 60
4 39 81 43.3 90
5 52 108 57.8 120
6 58.5 121.5 65 135
7 65 135 72.2 150
8 13 27 14.444 thirty
9 26 54 28.889 60
10 39 81 43.333 90
eleven 52 108 57.778 120
12 78 162 86.667 180
13 104 216 115.556 240
14 117 243 130 170
15 130 270 144.444 300
Unit: Mbit / s 1
• IEEE 802.11ac: 6.5 to 867 Mbit / s 1
Transmitter output power
The maximum transmit power will vary according to the rules of radio frequency regulation in your country.
The region Russia (RU) transmitter output power is limited to 20 dBm in the band 2400 - 2483.5 MHz and 5150 - 5350 MHz, the maximum transmitter power without restrictions - up to 22 dBm.
• IEEE 802.11a:
    15 ± 2 dBm at 6 ~ 54 Mbit / s
• IEEE 802.11b:
    17 ± 2 dBm at 1, 2, 5.5 and 11 Mbit / s
• IEEE 802.11g:
    17 ± 2 dBm at 6 ~ 36 Mbit / s
    15 ± 2 at 48 dBm and 54 Mbit / s
• IEEE 802.11n:
    2.4 GHz / HT-20:
    17 ± 2 dBm at MCS0-MCS15
    2.4 GHz / HT-40:
    5GHz / HT-20:
    15 ± 2 dBm at MCS0-MCS5, MCS8-MCS13
    14 ± 2 dBm at MCS6-MCS7, MCS14-MCS15
    5GHz / HT-40:
• IEEE 802.11ac:
    VHT-20:
    15 dBm at MCS0-MCS8
    13 dBm at MCS9
     VHT-40:
    15 dBm at MCS0-MCS8
    12 dBm at MCS9
    VHT-80:
    15 dBm at MCS0-MCS8
    12 dBm at MCS9
Receiver Sensitivity
• IEEE 802.11a:
    -86 ± 2 dBm at 6 and 9 Mbit / s
    -84 ± 2 dBm at 12 Mbits / s
    ± 2 -81 dBm at 18 Mbit / s
    -77 ± 2 dBm at 24 Mbits / s
    ± 2 -75 dBm at 36 Mbit / s
    ± 2 -68 dBm at 48 Mbit / s
    ± 2 -67 dBm at 54 Mbit / s
• IEEE 802.11b:
    ± 2 -92 dBm at 1 Mbit / s
    -90 ± 2 dBm at 2 Mbit / s
    ± 2 -88 dBm at 5.5 Mbit / s
    ± 2 -85 dBm at 11 Mbit / s
• IEEE 802.11g:
    -87 ± 2 dBm at 6 and 9 Mbit / s
    -85 ± 2 dBm at 12 Mbits / s
    ± 2 -82 dBm at 18 Mbit / s
    -79 ± 2 dBm at 24 Mbits / s
    ± 2 -76 dBm at 36 Mbit / s
    ± 2 -71 dBm at 48 Mbit / s
• IEEE 802.11n:
    2.4 GHz / HT-20:
    -85 ± 2 dBm at MCS0 / 8
    -82 ± 2 dBm at MCS1 / 9
    -80 ± 2 dBm at MCS2 / 10
    -77 ± 2 dBm at MCS3 / 11
    -74 ± 2 dBm at MCS4 / 12
    -69 ± 2 dBm at MCS5 / 13
    -68 ± 2 dBm at MCS6 / 14
    -65 ± 2 dBm at MCS7 / 15
    2.4 GHz / HT-40:
    -82 ± 2 dBm at MCS0 / 8
    -79 ± 2 dBm at MCS1 / 9
    2 dBm at MCS2 / 10
    -74 ± 2 dBm at MCS3 / 11
    -71 ± 2 dBm at MCS4 / 12
    -66 ± 2 dBm at MCS5 / 13
    -65 ± 2 dBm at MCS6 / 14
    -62 ± 2 dBm at MCS7 / 15
    5GHz / HT-20:
    -77 ± 2 dBm at MCS2 / 10
    -70 ± 2 dBm at MCS4 / 12
    -64 ± 2 dBm at MCS7 / 15
    5GHz / HT-40:
    -79 ± 2 dBm at MCS0 / 8
    -76 ± 2 dBm at MCS1 / 9
    -74 ± 2 dBm at MCS2 / 10
    -71 ± 2 dBm at MCS3 / 11
    -67 ± 2 dBm at MCS4 / 12
    -64 ± 2 dBm at MCS5 / 13
    -63 ± 2 dBm at MCS6 / 14
• IEEE 802.11ac:
    VHT-20:
    -82 DBm at MCS0
    -79 DBm at MCS1
    -77 DBm at MCS2
    -74 DBm at MCS3
    -70 DBm at MCS4
    -66 DBm at MCS5
    -65 DBm at MCS6
    -64 DBm at MCS7
    -59 DBm at MCS8
    -57 DBm at MCS9
    VHT-40:
    -79 DBm at MCS0
    -76 DBm at MCS1
    -74 DBm at MCS2
    -71 DBm at MCS3
    -67 DBm at MCS4
    -63 DBm at MCS5
    -62 DBm at MCS6
    -61 DBm at MCS7
    -56 DBm at MCS8
    -54 DBm at MCS9
    VHT-80:
    -76 DBm at MCS0
    -73 DBm at MCS1
    -71 DBm at MCS2
    -68 DBm at MCS3
    -64 DBm at MCS4
    -60 DBm at MCS5
    -59 DBm at MCS6
    -58 DBm at MCS7
    -53 DBm at MCS8
    -51 DBm at MCS9
Functionality
Network Management
• Web-interface (HTTP / HTTPS)
• Control via Wireless Controller DWC-1000, DWC-2000
• Telnet / SSH
• SNMP Support
Supported Features
• Quality of Service (QoS)
• WMM
Physical parameters
The weight • 500 g
Sizes
• Diameter: 158.79
• Height: 69.39 mm (without bracket) / 77.26 (with bracket)
terms of Use
Food
• The power adapter (not supplied)
     Output: 12V DC 2A
• The power cable for Ethernet (PoE) 802.3at
Max Power Consumption • 16,6 W
Temperature
• Operating: 0 ° to 40 ° C
• Storage: -20 ° to 65 ° C
Humidity
• Storage: 5% to 95% non-condensing
Contents of delivery
• Wireless Access Point DWL-6610AP
• Mounting bracket (with screws)
• Clamps for mounting on the ceiling
• Ethernet-Cable
• CD
• Warranty Card
Other
Certifications
• CE
• EN 301 893 V1.7.1 (2012-06) (DFS / TPC)
• EN 300 328 V1.8.1 (2012-06)
• FCC
• IC
• cUL
• LVD
• UL2043 (only for housing class "plenum")
• C-Tick
• BSMI
• NCC
• Wi-Fi
1 Maximum wireless signal rate derived from IEEE 802.11ac specifications, standards, and IEEE 802.11n. The data rate can vary significantly from the speed of the wireless connection. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. In the range of the wireless network can be affected by environmental factors.
 This function is available when using a unified access point, together with standardized wireless switches.
Ürünler | Destek  | Haberler  | Hakkında |
