DWL-1750EOL EOS
Tanımlama
Designed for Outdoor Environments
The DWL-1750 is designed for harsh outdoor environments. With die-cast watertight housing and built-in lightning protector (surge arrester), the DWL-1750 is the most robust outdoor wireless bridge/router for enterprise networks on the Wireless LAN market. It includes cost-effective Power over Ethernet (PoE) and unique outdoor remote mounted design for easy installation. With a one-meter RF cable needed between the DWL-1750 and the external antenna, the DWL-1750 is a cost-effective pure outdoor solution for long distance communications. D-Link provides ANT24 series outdoor antenna for range extension. The DWL-1750 is great for use in severe environments such as manufacturing plants, industrial locations, military bases, airports, golf courses, and other outdoor wireless LAN applications.
Data Encryption and User Access Security
The device provides up to 128-bit WEP data encryption. IEEE 802.1x user authentication support working in conjunction with RADIUS servers and MAC address control are provided for user access security.
Built-in DHCP Server
The DWL-1750 has a built-in DHCP server. The DHCP Server will automatically assign an IP address to the computers on the LAN/private network. When you turn your computers on, they will automatically load the proper TCP/IP The device provides up to 128-bit WEP data encryption. IEEE 802.1x user authentication support working in conjunction with RADIUS servers and MAC address control are provided for user access security. The DHCP server will automatically allocate an unused IP Address from the IP address pool to the requesting computer.
Router and Firewall
The DWL-1750 can operate as a NAT inbound virtual server and provides IP based access control. The DWL-1750 firewall feature filters out unrecognized packets to protect your LAN network so all computers networked with the DWL-1750 are invisible to the outside world. Denial of Service (DoS) protection is also included with the DWL-1750 to prevent the wireless network from being hacked.
Virtual Server Support
You can make some of the LAN computers accessible from the Internet by enabling Virtual Server . Remote users accessing Web and FTP services via the public IP address can be automatically redirected to local servers in the LAN (Local Area Network.).
Versatile Management Capability
The DWL-1750 can be easily configured and managed via a web-based user interface, telnet or the built-in RS-232 console port. SNMP support with built-in MIB-I and MIB-II makes the DWL-1750 great for enterprise wireless network management.
