DWL-2100APEOL EOS
High Speed 2.4GHz (802.11g) Wireless 108Mbps Access Point
Tanımlama
Product Description:
D-Link®, the industry pioneer in wireless networking, introduces a performance breakthrough in wireless connectivity – D-Link AirPlus Xtreme GTM series of high-speed devices now capable of delivering transfer rates up to 15x faster than the standard 802.11b with the new D-Link 108G. With the new AirPlus Xtreme G DWL-2100AP Wireless Access Point, D-Link sets a new standard for wireless access points.
With the D-Link 108G enhancement, the DWL-2100AP can achieve wireless speeds up to 15x in a pure D-Link 108G environment through the use of new wireless technologies such as Packet Bursting, Fast Frame, Compression & Encryption, and Turbo mode. These technologies enable a throughput high enough to handle video/audio streaming and future bandwidth-intense applications. The DWL-2100AP Wireless Access Point also supports SNMP v.3 for better network management with the provided Wireless AP Manager software that manages network configuration and firmware upgrades. For Enterprise networks, the DWL-2100AP supports network administration and real-time network traffic monitoring via D-Link's D-View Network Management software.
The D-Link DWL-2100AP Access Point has been verified and successfully passed through the Intel Wireless Verification Program, which tests the compatibility of various access point devices and wireless service providers with common configuration of notebooks built on Intel® Centrino™ mobile technology**.
The DWL-2100AP features WDS (Wireless Distribution System) that can be configured to perform in any one of five modes: a Wireless Access Point, a Point-to-Point (PtP) bridge with another DWL-2100AP, a Point-to-Multipoint (PtMP) bridge, a Repeater for range extension, or as a Wireless Client. The WDS feature makes the DWL-2100AP an ideal solution for quickly creating and extending a wireless local area network (WLAN) in offices or other workplaces, or even at hotspots.
The DWL-2100AP Wireless Access Point comes with a detachable antenna utilizing a reverse SMA connector. By simply attaching a D-Link wireless antenna, you can increase the wireless range of the DWL-2100AP.
Wireless security is addressed as the DWL-2100AP Wireless Access Point uses WPA (Wi-Fi Protected Access) and 802.1X authentication to provide a higher level of security for data communication amongst wireless clients. The DWL-2100AP is also fully compatible with the IEEE 802.11b and 802.11g standards. With great manageability, versatile operation modes, solid security enhancement, the cost-effective D-Link AirPlus Xtreme G DWL-2100AP Wireless Access Point provides the ultra-fast 108Mbps* speed and everything else a network professional dreams of.
* Maximum wireless signal rate derived from IEEE Standard 802.11g specifications. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range.
** Intel, the Intel Inside Logo, Intel Centrino and the Intel Centrino logo are trademarks or registered trademarks of Intel Corporation or its subsidiaries in the United States and other countries.
This wireless access point product has been verified for basic compatibility with corresponding Intel® Centrino mobile technology based notebooks. Notebooks based on Intel Centrino mobile technology do not support proprietary 802.11g performance-enhancement features. Data rate, features and performance may vary based on the configuration of your notebook and other factors.
Genel Özellikler
Specifications
Standards
IEEE 802.11g
IEEE 802.11b
IEEE 802.11
IEEE 802.3
IEEE 802.3u
Device Management
Web-Based – Internet Explorer v6 or later; Netscape Navigator v6 or later; or other Java- enabled browsers.
SNMP v.3
AP Client
PtP Bridge
PtMP Bridge
Repeater
Security
64, 128, 152-bit WEP
802.1X (EAP-MD5, EAP-TLS, EAP-TTLS and EAP-PEAP)
WPA —Wi-Fi Protected Access
MAC Address Access Control (WPA-TKIP and WPA-AES)
Media Access Control
CSMA/CA with ACK
Wireless Frequency Range
2.4GHz to 2.4835GHz
Wireless Signal Range*
Indoors: Up to 328 ft (100 meters)
Outdoors: Up to 1312 ft (400 meters)
Modulation Technology
Orthogonal Frequency Division Multiplexing (OFDM)
Complementary Code Keying (CCK)
DQPSK
DBPSK
Wireless Transmit Power
15dBm (32mW) ± 2dB (Control TX power level from full, 50%, 25%, 125% and min.)
Receiver Sensitivity*
54Mbps OFDM, 10% PER,-66dBm)
48Mbps OFDM, 10% PER,-71dBm
36Mbps OFDM, 10% PER,-76dBm
24Mbps OFDM, 10% PER,-80dBm
18Mbps OFDM, 10% PER,-83dBm
12Mbps OFDM, 10% PER,-85dBm
11Mbps CCK, 8% PER,-83dBm
9Mbps OFDM, 10% PER,-86dBm
6Mbps OFDM, 10% PER,-87dBm
2Mbps QPSK, 8% PER,-89dBm
External Antenna Type
1.0dB Dipole with reverse SMA connector
LEDs
Power
LAN (10/100)
WLAN (Wireless Connection)
Temperature
Operating: 32°F to 140°F (0°C to 40°C)
Storing: 4°F to 149°F (-20°C to 65°C)
Humidity
95% maximum (non-condensing)
Power Input
Ext. Power Supply DC 5V, 2.0A
Safety & Emissions
FCC
UL
VCCI
CSA
EN
Dimensions
L = 5.6 inches (142mm)
W = 4.3 inches (109mm)
H = 1.2 inches (31mm)
Weight
0.44 lbs (200g)
Warranty
3 Year
Çözümler
Sipariş Bilgisi
Test order information
Görseller
DWL-2100AP/Ax
Front view
Back view
İndir
Destek Merkezi
