Hızlı Arama
Ürün Özellikleri:
Enhanced 2.4GHz (802.11b) Ethernet-to-Wireless Bridge
EOL
Genel Özellikler:
Standards
• IEEE 802.11
• IEEE 802.11b
• IEEE 802.3
• IEEE 802.3u
Port
10/100 Mbps Fast Ethernet
Auto MDIX
Data Rates
With Automatic Fallback
• 22Mbps    • 11Mbps
• 5.5Mbps   • 2Mbps
• 1Mbps
Encryption
64-,128-, 256-bit RC4
Media Access Control
CSMA/CA with ACK
Frequency Range
2.4GHz to 2.4385GHz
Operating Range
Indoors: Up to 328 ft (100m)*
Outdoors: Up to 1,312 ft (400m)
Modulation Technology
• PBCC - Packet Binary
   Convolutional Coding
• Direct Sequence Spread
   Spectrum (DSSS)
•11-chip Barker sequence
Modulation Techniques
• Barker (1Mbps/0db)
• Barker (2Mbps/3db)
• CCK (5.5 Mbps/5.5db)
• PBCC (5.5Mbps/1.5db)
• CCK (11Mbps/8.5db)
• PBCC (11Mbps/4.5db)
• PBCC (22Mbps/8.5db)
Power Input
External Power Supply
DC 5V, 2.5A
LEDs
• Power (Green)
• WLAN (Yellow)
Transmitter Output Power
15dBm ± 2dB
External Antenna Type
Detachable 1.0dB gain with reverse
SMA connector
Over-Driving Levels
Tolerates up to +17dBm at the antenna
Device Management
Web-Based – Internet Explorer v6 or later; Netscape Navigator v6 or later; or other Java-enabled browsers.
Fiziksel Özellikler
Temperature
Operating: 32°F to 131°F (0°C to 55°C)
Storing: 4°F to 167°F (-20°C to 75°C)
Humidity
95% maximum (non-condensing)
Safety & Emissions
• FCC
• UL
Dimensions
• L = 3.5 inches (90mm)
• W = 3.2 inches (82mm)
• H = 1.6 inches (40mm)
Weight
0.34 lbs (153g)
* Environmental factors may adversely affect wireless signal range.
Ürünler | Destek  | Haberler  | Hakkında |
