Tanımlama
The D-Link DWL-1000AP is an IEEE 802.11b compliant 11 M egabits per second (Mbps) Ethernet wireless Access Point. Once a c t ivated with the network, it provides Direct Sequence Spread Spectrum (DSSS) operation for wireless networks delivering transparent bridging and roaming capabilities for wireless nodes.
The D-Link DWL-1000AP provides an access point connections building Infrastructure for the network or to extend the reach of the network communications capability. It enables full mobility and seamless roaming from cell to cell. The range of coverage per cell for indoor use is up to 100 meters and up to 300 meter per cell for outdoor use.
In bridge mode, the DWL-1000AP can be directly connected to a broadband residential ga t eway or a xDSL/Cable modem to p r ovide high-speed wireless Internet access. On a dynamic network connection, the DWL-1000AP will automatically obtain a DHCP IP and forward additional DHCP IP’s to multiple clients on the network.
It strictly adheres to with the most advanced IEEE networking Standard for wireless connections, so the D-Link DWL-1000AP is very compatible with multi-vendor environments that also meet the standard compliance for IEEE 802.11b. The DWL-1000AP bandwidth data transmission rate can be set manually at 11Mbps, 5.5Mbps, 2Mbps, 1Mbps or it can be set on dynamic auto-sensing configuration.
The DWL-1000AP operates in 2.4 GHz Direct Sequence Spread Spectrum (DSSS) for wireless networks in the home or officee nvironment with transparent bridging and roaming capabilities. The DWL-1000AP can be managed remotely via the access point manager software. It also supports WEP (Wired Equivalent Privacy), MAC address control and user authentication to ensure a secure network connection.
The D-Link DWL-1000AP will automatically identify the IP of the host PC as well as the subnet when connected on to an Ethernet LAN in the home or office environment. In addition, with the easy to use access point manager software, the IP address of the DWL-1000AP can also be manually assigned. The access point manager software can be installed in Wi n d ows 95 OSR2, 98, 98SE, ME, 2000 and NT 4.0.
Genel Özellikler
Standards
- 802.11b+, IEEE 802.11b wireless LAN
- IEEE 802.3 10BASE-T Ethernet
- IEEE 802.3u 100BASE-TX Fast Ethernet
Frequency Range
2.4 - 2.4835 GHz
Operating Channels
- North America (FCC): 11
- Canada (DOC): 11
- Europe (ETSI): 13
- Japan (MKK): 14
Radio & Modulation Technology
- Packet Binary Convolution Coding (PBCC)
- Direct Sequence Spread Spectrum (DSSS)
- 11-chip Barker sequence
Modulation Techniques
- 22Mbps/8.5db: PBCC
- 11Mbps/8.5db: CCK
- 11Mbps/4.5: PBCC
- 5.5Mbps/5.5db: CCK
- 5.5Mbps/1.5db: PBCC
- 2Mbps/3db: Barker
- 1Mbps/0db: Barker
Data Rates
- 22 Mbps
- 11 Mbps
- 5.5 Mbps
- 2 Mbps
- 1 Mbps
- Auto fall-back
Antenna
Dual 2dbi Gain diplole fixed antennas
Transmitter Output Power
15dBm 2dB
Reception Sensitivity Nominal Temp Range
- 22Mbps: 10-5 BER @ -80 dBm minimum
- 11Mbps: 10-5 BER @ -79 dBm minimum
- 5.5Mbps: 10-5 BER @ -83 dBm minimum
- 1Mbps: 10-5 BER @ -89 dBm minimum
Operating Range
- Up to 100 m (328 feet) indoors*
- Up to 400 m (1,312 feet) outdoors*
Wireless LAN to Ethernet Interface
2 RJ-45 10/100Mbps Fast Ethernet ports
Diagnostic LEDs
- Power/Status
- Diagnostic
- Wireless
- Ethernet
Software
- Operating Modes
- Access Point
- Access Point to Access Point bridging
- Access Point to multi
- Point bridging
- Wireless client
- Repeater
Roaming
Among Access Points on the same subnet
IP Number Assignment
Automatic through built-in DHCP server
Security
- Data encryption: 64-bit, 128-bit, 256-bit WEP (Wired Equivalent Privacy)
- Connected node access control list
Configuration & Management
- Manage wireless LAN, network connection and client access control
Through web browser (Java Script supported)
- TFTP client for firmware upgrade
- Set IP session (ARP/ping)
- DHCP client (IP number self-assignment)
* Environmental factors may adversely affect operating range
Çözümler
Sipariş Bilgisi
802.11b+ Wireless LAN Access Point
DWL-1000AP+ Wireless LAN Access Point
