Tanımlama
Easiest Way to Expand
If you're a network administrator, the versatile 802.11a/b/g-compatible DWL-AG530 card gives you an immediate way to expand your existing 802.11b network and protect your overall wireless network investment. By installing DWL-AG530 network cards in desktops throughout your organization, your employees can access wireless Access Points and routers from their desktop PCs. And as your company expands or reorganizes, you won't have to keep pulling and plugging Ethernet cables because no matter where the workstation is relocated, it's still connected to the network.
End-to-End Wireless Solution
When you add an 802.11a/b/g access point (D-Link AirPremierAG DWL-7100AP) or router (D-Link AirPremierAG DI-784) to your wireless network, you will have an end-to-end wireless solution capable of handling up to 15 times the user load of your current 802.11b network. In addition to its compatibility with earlier 802.11b networks, the DWL-AG530 offers the robust speed, up to 108Mbps (Turbo mode), of the newer 802.11g and 802.11a standards, so everyone can work faster and more efficiently.
108Mbps Dualband High Speed
In addition to the 2.4GHz frequency band operated by 802.11b and g, the 5GHz band used by 802.11a also offers a way to quickly transfer data in a frequency range that does not experience interference or interruptions from cordless phones, microwave ovens and other devices utilizing the 2.4GHz frequency.
AES and 802.1x Support
The adapter supports AES enhanced security and 802.1x for user authentication, providing a formidable barrier to hackers and sniffers, allowing users to securely share data over the network.
WPA/WPA2 EAP Support
Enhanced security is provided with Wi-Fi Protected Access (WPA) to authorize and identify users based on a secret key that changes automatically at a regular interval. Used in conjunction with a RADIUS server, WPA/WPA2 employs TKIP (Temporal Key Integrity Protocol) to change the temporal key every 10,000 packets. This insures much greater security than the standard WEP security, which requires the keys to be changed manually. The adapter supports WPA/WP A2-EAP (Extensible Authentication Protocol) for authentication of 802.11 clients using server-side digital certificates. EAP creates an SSL/TLS tunnel between each client and the authentication server, which protects subsequent user authentication exchange.
This function brings a lot of convenience for users who do not incorporate a RADIUS server in their networks. Utilizing the Pre Shared Key (PSK) mode of WPA/WPA2, the adapter gives each user a new security key every time he connects to the network. Users only need to input their encryption information once in the configuration menu. Each user will automatically receive a new key every time he connects, and the inconvenience of manual WEP key input is eliminated.
Genel Özellikler
System Requirements
- Laptop with available CardBus Type II slot
- Windows XP , 2000, ME or 98/SE
- 300MHz CPU or above
- 32MB memory or more
Standards
- IEEE 802.11a
- IEEE 802.11b
- IEEE 802.11g
Bus Type
- PCI 2.2
- PCI 32-bit interface
Media Access Control
CSMA/CA with ACK
Data Rates
(With automatic fallback)
54Mbps, 48Mbps, 36Mbps, 24Mbps, 18Mbps, 12Mbps, 11Mbps, 9Mbps, 6Mbps, 5.5Mbps, 2Mbps, 1Mbps
Modulation Technology
- Orthogonal Frequency Division Multiplexing (OFDM)
- Complementary Code Keying (CCK)
- Direct Sequence Spread Spectrum (DSSS)
Frequency Range *
- 2.4GHz to 2.4835GHz
- 5.15GHz to 5.250GHz
- 5.725GHz to 5.850GHz
* Software configurable as allowable frequency will vary from country to country in the European region.
Transmit Output Power
- 802.11a:
+10 to 13dBm for 54Mbps
+11 to 14dBm for 48Mbps
+13 to 16dBm for 36Mbps
+15 to 17dBm for 24, 18, 12, 9 and 6Mbps
- 802.11b:
+18dBm for 11, 5.5, 2 and 1Mbps
- 802.11g:
+11 to 15dBm for 54Mbps
+12 to 16dBm for 48Mbps
+13 to 17dBm for 36Mbps
+16 to 18dBm for 24, 18, 12, 9 and 6Mbps
Receive Sensitivity
- 802.11a (@ 10% PER):
-87dBm for 6Mbps
-86dBm for 9Mbps
-85dBm for 12Mbps
-83dBm for 18Mbps
-80dBm for 24Mbps
-76dBm for 36Mbps
-71dBm for 48Mbps
-66dBm for 54Mbps
- 802.11b (@ 8% PER):
-84dBm for 11Mbps
-90dBm for 2Mbps
- 802.11g (@ 10% PER):
-87dBm for 6Mbps
-86dBm for 9Mbps
-85dBm for 12Mbps
-83dBm for 18Mbps
-80dBm for 24Mbps
-76dBm for 36Mbps
-71dBm for 48Mbps
-66dBm for 54Mbps
Antenna
4dBi to 5dBi Gain omni-directional dipole antenna
Operation Range
- Indoors: up to 100 meters (328 feet)*
- Outdoors: up to 400 meters (1,312 feet)*
* Environmental factors may adversely affect range
Security
- 64/128/152-bit WEP data encryption
- 802.1x authentication
- 802.11a SSID broadcast (ad hoc mode): disabled
- WPA/WP A2-PSK, and WPA/WPA2-EAP
- Cipher Mode AES and TKIP
Çözümler
Sipariş Bilgisi
DWL-AG530 802.11a/g Wireless LAN PCI Card
