Tanımlama
Dual Access Points & Router Functions
The Wireless Pocket Router/AP might be small in size, but is huge in functionality. The DWL-G730AP supports multiple operation modes including: Access Point (AP) mode to create a wireless connection; Router mode to share an Internet connection; and Wireless Client mode to connect an existing wireless network. Easily switch between these modes by using the 3-way configuration switch located at the bottom.
In AP mode, the DWL-G730AP can be used to create a wireless network in a room where a single Ethernet port is provided. Now multiple wireless clients can connect to the network at the same time to share resources and files.
In Router mode, the DWL-G730AP can be used to share a single broadband Internet connection, such as in a hotel room. The internal DHCP server automatically assigns IP addresses to ensure everyone in the room can connect to the Internet. In addition, the DWL-G730AP supports VPN Pass-through and firewall features including Network Address Translation (NAT) and MAC filtering to protect your wireless network from malicious attacks.
Wireless Connections Without AC Power Source
When set in Wireless Client mode, the DWL-G730AP allows connection to an existing wireless network, without having to install complicated drivers or additional software. For added mobility, the DWL-G730AP can be powered over USB if power outlets are not available.
Enhanced Network Security
The Pocket Router/AP supports WPA-PSK to secure your wireless data communications. In AP mode, the DWL-G730AP adds support for 802.1x user authentication with an external RADIUS server. For setup and configuration the DWL-G730AP can be accessed via D-Link's user-friendly Web-based utility.
Convenient For Traveling
The DWL-G730AP is smaller than the average PDA, easy to pack and convenient for traveling. It comes with an attractive traveling case, which also provides accessories including cables and a power adapter.
Genel Özellikler
Standards
- IEEE 802.11b
- IEEE 802.11g
- IEEE 802.3
- IEEE 802.3u
Network Data Transfer Rates
- For 802.11g: 54, 48, 36, 24, 18, 12, 9 and 6Mbps
- For 802.11b: 11, 5.5, 2, and 1Mbps
Wireless Frequency Range
2.412GHz to 2.462GHz
Wireless Operating Range *
(802.11g full power with internal antenna, outdoors)
- 50 m (164ft) @ 54Mbps
- 150 m (492ft) @ 11Mbps
- 200 m (656ft) @ 6Mbps
* Environmental factors may affect operation range.
Radio and Modulation Type (for 802.1 1g)
- OFDM:
BPSK @ 6 and 9Mbps
QPSK @ 12 and 18Mbps
16QAM @ 24 and 36Mbps
64QAM @ 48 and 54Mbps
- DSSS:
DBPSK @ 1Mbps
DQPSK @ 2Mbps
CCK @ 5.5 and 11Mbps
Radio and Modulation Type (for 802.1 1b)
- DSSS:
DBPSK @ 1Mbps
DQPSK @ 2Mbps
Wireless Transmit Power
(Typical RF Output Power at each Data Rate)
- For 802.11g:
31mW (15dBm) @ 54Mbps
40mW (16dBm) @ 48Mbps
40mW (16dBm) @ 36, 24, 18, 12, 9, and 6Mbps
- For 802.11b:
50mW (17dBm) @ 11, 5.5, 2, and 1Mbps
Receiver Sensitivity
- For 802.11g:
6Mbps: -87dBm
9Mbps: -85dBm
12Mbps: -82dBm
18Mbps: -81dBm
24Mbps: -80dBm
36Mbps: -79dBm
48Mbps: -71dBm
54Mbps: -69dBm
- For 802.11b:
1Mbps: -90dBm
2Mbps: -90dBm
5.5Mbps: -86dBm
11Mbps: -85dBm
Security
- 64/128-bit WEP data encryption
- WPA PSK security
- MAC address filtering
- SSID broadcast disable
Device Management
Web-Based Internet Explorer v .6 or Netscape Navigator v.7
Çözümler
Sipariş Bilgisi
DWL-G730AP 802.11g Pocket Router/AP
