DWL-G630EOL EOS
High-Speed 2.4GHz(802.11g) Wireless Cardbus Adapter
Tanımlama
D-Link, the industry pioneer in wireless networking, introduces another performance breakthrough in wireless connectivity—the D-Link AirPlus™ G series of high-speed devices.The D-Link AirPlus G DWL-G630 Cardbus Adapter is a wireless cardbus featuring the very latest in advanced wireless silicon chip technology including enhanced security to shield and protect your wireless communication from intruders.The DWL-G630 also works with 802.11b standard wireless devices and when used with other D-Link AirPlus G products delivers throughput speeds capable of handling heavy data payloads.
The DWL-G630 features WPA and 802.1x for wireless user authentication, providing you a much higher level of security for your data and communications.
The D-Link AirPlus G DWL-G630 also includes a configuration utility to discover available wireless networks and create and save detailed connectivity profiles for those networks most often accessed.
The DWL-G630 is a powerful 32-bit Cardbus Adapter that installs quickly and easily into laptop PCs and when used with other D-Link AirPlus G products automatically connects to the network. Like all D-Link wireless adapters, the DWL-G630 can be used in Ad-Hoc mode to connect directly with other cards for peer-to-peer file sharing or in Infrastructure mode to connect with a wireless access point or router for access to the Internet in your office or home network.
1 Maximum wireless signal rate based on IEEE Standard 802.11g specifications. Actual data throughput will vary. Network conditions and environmental factors lower actual data throughput rate.
2  WPA and 802.1x requires use of the Windows® XP Zero Configuration Utility.
Genel Özellikler
Wireless Standards
- 802.11g wireless LAN
- 802.11b wireless LAN
Adapter Type
PC Card Type II CardBus
Media Access Control Protocol
CSMA/CA with ACK
Network Architecture Types
- Ad-hoc mode
- Infrastructure mode
Operating Frequency
2.4 to 2.4835 GHz ISM band
Operating Channels
- FCC: 11
- ETSI: 13
Radio and Modulation Schemes
- 802.11b: DQPSK, DBPSK, DSSS, CCK
- 802.11g: BPSK, QPSK, 16QAM, 64QAM, OFDM
Receive Sensitivity (for 802.11b)
-  84dBm at 11Mbps (8% PER)
-  90dBm at 2Mbps (8% PER)
Receive Sensitivity (for 802.11g)
(1000-byte PDUs 10% PER)
- -87dBm at 6Mbps
- -86dBm at 9Mbps
- -85dBm at 12Mbps
- -83dBm at 18Mbps
- -80dBm at 24Mbps
- -76dBm at 36Mbps
- -71dBm at 48Mbps
- -66dBm at 54Mbps
Transmit Output Power (for 802.11b)
+18dBm at 11Mbps, 5.5Mbps, 2Mbps, and 1Mbps
Transmit Output Power (for 802.11g)
- +12dBm to 16dBm at 54Mbps
- +13dBm to 17dBm at 48Mbps
- +16dBm to 17dBm at 36Mbps
- +17dBm to 19dBm at 24, 18, 12, 9, and 6Mbps
Security
- 64/128/152-bit WEP data encryption
- WPA EAP, WP A PSK
Antennas
Integrated printed-PCB antennas with dual diversity
Operation Range
- Indoors: up to 100 meters (328 feet) *
- Outdoors: up to 400 meters (1,312 feet) *
* Environmental factors may adversely affect range
Çözümler
Sipariş Bilgisi
DWL-G630    802.11g Wireless LAN CardBus Adapter
Görseller
DWL-G630
Front view
Left side view
İndir
Destek Merkezi
