Hızlı Arama
Ürün Özellikleri:
Wireless N Router
Tanımlama:
802.11N HIGH-SPEED WIRELESS INTERNET ACCESS
Upgrade your home with the D-Link DIR-615 Wireless N Router to share Internet connection and provide wireless connection for video, music, photo and document sharing. This router uses the Intelligent Antenna technology to transmit multiple streams of data which enable you to receive wireless signals in the farthest corners of your home. Not only does it extend your wireless range, it also works with your existing 802.11g and 802.11b wireless devices.
IPv6 READY
This router carries both the silver and gold IPv6 Ready logos, signifying that it not only supports the IPv6 protocol, but is also compatible with IPv6 equipment from other manufacturers. It allows you to move to a 128-bit addressing system and directly connect to anybody in the world using your unique IP address. Using a dual-stack architecture, this router can handle routing for both IPv4 and IPv6 networks at the same time, so you can be assured that your equipment is forward and backward compatible.
EASY TO SECURE
The DIR-615 supports the latest wireless security features to help prevent unauthorized access, be it from over a wireless network or from the Internet. Support for WEP, WPA and WPA2 standards ensure that you will be able to use the best possible encryption, regardless of your client devices. In addition, this Wireless N Router utilizes dual active f rewalls (SPI and NAT) to prevent potential attacks from the  Internet.
EASY TO SET UP
The D-Link Click’n Connect quickly conf gures your new Wireless N Router to get you up and running in minutes. D-Link’s Click’n Connect Setup walks you step by step through the installation process to conf gure your Internet connection, wireless network settings and security, and everything else you need to get your network up and running so you can easily set it up even if you are not a networking expert.
Ürünler | Destek  | Haberler  | Hakkında
