STANDARDS
+ IEEE 802.11n (draft 2.0)
+ IEEE 802.11g
+ IEEE 802.11b
+ IEEE 802.3
+ IEEE 802.3u
DEVICE INTERFACES
+ 4 10/100 LAN ports
+ 1 10/100 WAN port
+ IEEE 802.11 b/g/n WLAN
ANTENNAS
Dual external 2dBi Gain reverse SMA antennas
SECURITY
+ 64/128-bit Wired Equivalent Privacy (WEP) data encryption
+ Wi-Fi Protected Access (WPA, WPA2)
ADVANCED FIREWALL FEATURES
+ Network Address Translation (NAT)
+ Stateful Packet Inspection (SPI)
+ VPN Pass-through / Multi-sessions PPTP / L2TP / IPSec
DEVICE MANAGEMENT
+ Internet Explorer v.6 or later, Mozilla Firefox v.2.0 or later, or other Java-enabled browser
+ UPnP support
+ DDNS (Dynamic DNS)
MINIMUM SYSTEM REQUIREMENTS
+ Computer with:
- Pentium 3 800GHz or better processor
- 256MB RAM or higher
- Windows Vista, XP SP2, 2000, 2003 or Mac OS X v10.4 or higher
- CD ROM drive
IP PROTOCOL SUPPORT
+ IPv4
+ IPv6
LEDS
+ Power / Status
+ WAN / Internet
+ WLAN (Wireless Connection)
+ LAN (10/100)
POWER INPUT
DC 5V 2.5A, through external power adapter
DIMENSIONS
193 x 116.8 x 30.5 mm (7.6 x 4.6 x 1.2 inches)
WEIGHT
940 grams (0.7 lb)
CERTIFICATIONS
+ FCC Class B
+ CE
+ C-Tick
+ IC
+ Wi-Fi
+ Wi-Fi Protected Setup (WPS)
+ Works with Windows Vista
Fiziksel Özellikler
