Hızlı Arama
Ürün Özellikleri:
G.SHDSL access device
Genel Özellikler:
Fiziksel Özellikler
Model
DSL-1510G, 2-wire, 4-port Ethernet
The line interface - G.SHDSL.bis
• Type: 2-wire
• Speed: nx 64 kbit / s, n = 3 ~ 89, n = 3 ~ 213 (for extended mode)
• Standards: ITU-T G.991.2, ETSI 101 524
• Connection protocols: IEEE 802.3ah EFM 2Base-TL; TDM; DBM; HDLC
• Connector: 1xRJ-45
• Line Coding: TC-PAM 16/32/64/128
• Impedance: 135 Ohm
• ITU K.21 compliant
Ethernet Interface
• The type of Ethernet: 10/100 BaseT
• Connector: RJ-45
• 802.3x flow control support
• Auto MDI / MDIX on all ports
• Auto-negotiation of speed and duplex mode
• Supports full-duplex and full-duplex modes
The function clock source
• Internal
• resulting from the DSL line
Ethernet functions Level 2
• Supports 802.1d transparent bridge
• Supports filtering by MAC-based
• Bandwidth control on each port (Step = 64K, up to 100M)
• Up to 2K (2048) studied MAC-addresses
• Support for Ethernet packet size to 1518/1522/1536 bytes
• Support for 802.1q VLAN tagging
• Supports 802.1p QoS
Management
• Setting up a CID-console (debug only), Telnet, WEB-interface
• Support for web-browsers: IE, Firefox, Chrome
• Console Connector: DB9 (RS232C)
• Support for remote management
• Diagnosis of local and remote loop
• The performance monitoring
• TST button to verify that the DSL-connections
• The Reset button to return to the default settings
Indicators
PWR, TST, ALM, CPE, DSL 1 ~ 4, LAN 1 ~ 4
The physical parameters
Nutrition
• AC / DC, DC / DC external power supply (12V, 1A)
• Dual power connector 12V DC for power backup
• Power consumption: 6 W
Measurements
200 (W) x 150 (D) x 39 (H) mm
Operating conditions
• Operating Temperature: 0 ~ 50 ° C
• Storage Temperature: -40 ~ 70 C
• Humidity: 90% non-condensing
Ürünler | Destek  | Haberler  | Hakkında |
