Hızlı Arama
Ürün Özellikleri:
Wireless modem / router ADSL2 + with support for 802.11n (up to 150 Mbit / s) and USB-port
Tanımlama:
USB-port
3G-modem connecting to USB-port router, you can connect to the Internet via 3G GSM. There is also a USB-port to connect a printer or storage device.
ADSL-port and 4-port switch, support Ethernet WAN
ADSL-router has a port for connecting to ADSL-line. Built-in 4-port switch allows you to connect computers equipped with Ethernet-adapters, game consoles and other devices to your network. In addition, any Ethernet-port devices can be used to connect to a dedicated Ethernet-line.
Safety
Wireless Router DSL-2650U has a built-in firewall. Advanced security features minimize threats of hackers and prevent intrusions to your network and access to unwanted websites for users on your local network.
Wireless Interface
You can quickly create a wireless network at home or in the office, which will allow your employees or members of your family to connect to a wireless network from virtually anywhere (in the range of a wireless network). The Router can serve as a base station for a wireless network device of the standards 802.11b, 802.11g and 802.11n.
The device supports several security standards (WEP, WPA/WPA2), filtration devices to be connected by MAC-address, and allows the use of technology WPS.
Configuration and Management
To manage and configure the router DSL-2650U uses a simple and user-friendly web-based interface (available in several languages).
Ürünler | Destek  | Haberler  | Hakkında |
