DSL-300T/RUEOL EOS
ADSL Modem
Tanımlama
High-Speed Internet Connection
The DSL-300T features the latest ADSL2/ADSL2+ standards, providing speeds of up to 24Mbps downstream and 1Mbps upstream (ADSL2+), or 12Mbps downstream and 1Mbps upstream (ADSL2). The modem auto-senses the connection type and auto-negotiates the best modulation scheme, using the G.hs (handshake) protocol. The high speeds make it possible to watch streaming video while carrying out large data transfer or engaging in a voice communication over the Internet.
Uses Existing Telephone Line
Your ADSL modem operates over the existing telephone wire and does not require any new transmission media. The DSL-300T makes possible high-speed multimedia services, Internet access, and video conferencing for you, using a standard copper phone line.
"Always-on" or Dial-up Connection to ISP
The DSL-300T supports both "always on" and dial-up connections to ISP. "Always-on" eliminates the need to dial to ISP and is ideal for applications like IP telephony . Dial-up connection lets you save ISP charge, it allows you to disconnect from the Internet when you don't need to use it.
10/100Mbps Fast Ethernet Interface to Host
DSL-300T can connect to your computer, router or other hosts through a 10/100BASE-TX Fast Ethernet interface, commonly found in most computer equipment today. The modem auto-senses the host's Ethernet interface and auto-negotiates for highest available Ethernet speed.
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DSL-300T/RU
Front view
İndir
Destek Merkezi
