Tanımlama
The DSL-524T ADSL router is a versatile, high-speed remote router for home and the small office. With integrated ADSL2/2+ supporting up to 24Mbps download speed, firewall protection, Quality of Service (QoS) and 4 Ethernet switch ports, this router provides all the functions that a home or small office needs to establish a secure and high-speed remote link to the outside world.
High-Speed ADSL Connection. The DSL-524T features the latest ADSL2/ADSL2+ standards, providing speeds of up to 24Mbps downstream and 1Mbps upstream (ADSL2+), or 12Mbps downstream and 1Mbps upstream (ADSL2). This router auto-senses the connection type and auto-negotiates the best modulation scheme, using the G.hs (handshake) protocol. Shared Internet Access for Workgroup. The DSL-524T provides DHCP server for a group of home or office users to simultaneously access the Internet. It integrates 4 10/100Mbps Ethernet switch ports for ready connection to 4 computers, saving you the cost and trouble of installing a separate Ethernet switch.
Firewall Protection. The DSL-524T provides firewall security using Stateful Packet Inspection (SPI) and hacker attack logging for Denial of Service (DoS) attack protection. SPI inspects the contents of all incoming packet headers before deciding what packets are allowed to pass through. Access control is provided with packet filtering based on port and source/destination MAC/IP addresses. With Virtual Server Mapping, the router can be set to allow separate FTP, Web, and multiple games to share the same Internet-visible IP address while still protecting your servers and workstations from hackers. You can configure any of the built-in LAN ports of the router to function as a DMZ port. VPN pass-through is provided to let mobile users access files and mail from offices to work at home without having to use complex VPN client software.
Quality of Service Features. The DSL-524T supports 4 priority queues to enable a group of home or office users to experience the benefit of smooth network connection of inbound and outbound data without concern of traffic congestion. This QoS support allows you to enjoy high ADSL transmission for applications such as VoIP, multimedia and on-line games over the Internet.
Genel Özellikler
Hardware
Interfaces
• 1 RJ-11 ADSL port
• 4 RJ-45 10/100BASE-TX Fast Ethernet LAN switch ports with auto MDI/MDIX
• Factory reset button
ADSL
Standards
• ADSL standards: ANSI T1.413 Issue 2, ITU G.992.1 (G.dmt) Annex A, ITU G.992.2 (G.lite) Annex A
• ADSL2 standards: ITU G.992.3 (G.dmt.bis) Annex A, ITU G.992.4 (G.lite.bis) Annex A
• ADSL2+ standards: ITU G.992.5 Annex A
• Auto-handshake: ITU G.994.1 (G.hs)
Data Rates
• G.dmt: 8Mbps downstream, 832Kbps upstream
• G.lite: 1.5Mbps downstream, 512Kbps upstream
• ADSL2: 12Mbps downstream, 1Mbps upstream
• ADSL2+: 24Mbps downstream, 1Mbps upstream
ATM & PPP Protocols
• ATM Adaptation Layer Type 5 (AAL5)
• Bridged or routed Ethernet encapsulation
• VC and LLC based multiplexing
• PPP over Ethernet (PPPoE)
• PPP over ATM (RFC 2364)
• Classical IP over ATM (RFC 1577)
• OAM F4/F5
Router
• Network Protocols & Features
• NAT, Static Routing, RIP v.1, v.2
• Universal Plug and Play (UPnP) Compliant
• Dynamic Domain Name System (DDNS)
• Virtual Server & DMZ
• SNTP, IGMP proxy
Firewall/Access Security
• Built-in NAT firewall
• DoS attacks prevention (IP Spoofing, Land Attack,Smurf Attack, Ping of Death, TCP SYN flooding)
• Packet filtering based on port, source IP address, destination IP address, MAC address (ICMP/TCP/UDP)
Virtual Private Network (VPN)
PPTP/IPSec pass-through
QoS Control
• LAN to WAN traffic prioritization/bandwidth management
• 802.1p traffic prioritization (4 queues)
Security/Bandwidth Management
• IGMP Snooping with 32 Multicast groups
• PVC/VLAN port mapping (4 VLANs)
• Firewall/Access Security Bandwidth management based-on IP protocol, port number, MAC address
