Hızlı Arama
Ürün Özellikleri:
Cloud wireless gigabit router with data transfer rates up to 300 Mbit / s
Genel Özellikler:
Fiziksel Özellikler
Device Interfaces
• 802.11 n / g / b
• 4 Gigabit LAN-port
• Gigabit WAN-port
• USB 2.0 port
Antenna Type
Internal Antenna
Standards
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
• IEEE 802.3
• IEEE 802.3u
The output power of the transmitter
• IEEE 802.11b
  20dBm at 1,2,5.5,11 Mbit / s for US
  17dBm at 1,2,5.5,11 Mbit / s for the EU
  24dBm at 1,2,5.5,11 Mbit / s for AU
• IEEE 802.11g
  6 ~ 18dBm at 54 Mbit / s for US
  6 ~ 17dBm at 54 Mbit / s for the EU
  For AU:
  + 21dBm at 6 ~ 24 Mbit / s
  + 19dBm at 36 ~ 48 Mbit / s
  + 18dBm at 54 Mbit / s
• IEEE 802.11n (2.4GHz)
  MCS0 ~ 17dBm at 15 for US
  MCS0 ~ 14dBm at 15 for EU
  For AU:
  + 20dBm at MCS0 ~ 3/8 ~ 11
  + 19dBm at MCS4 ~ 6/12 ~ 14
  + 18dBm at MCS7/15
Minimum System Requirements
• Windows 7/Vista/XP SP3 or Mac OS X 10.4 or higher
• Microsoft Internet Explorer 6 or higher, Firefox 1.5 or later, or other Java-enabled browser
• The AC adapter (NIC)
• Cable or DSL-modem
• Subscribe to a service provider
Safety
• WPA and WPA2 (Wi-Fi Protected Access)
• Wi-Fi Protected Setup (WPS) - PIN / PBC
Advanced Features
• The Guest Zone
• Web-Wizard in several languages
• Green Ethernet Technology
• Supports UPnP
• The firewall
  - Network Address Translation (NAT)
  - Stateful Packet Inspection (SPI)
• Modes VPN passthrough / multi-session PPTP/L2TP/IPSec
Functions mydlink
• Remote control
  - View the current bandwidth information outgoing / incoming connections
  - View clients connected at the moment
  - View the browser history for each customer
  - Lock / Unlock network access to the client
  - Management of the wireless network
• Access through a Web-browser or mobile app for iOS or Android
Functions SharePort
• Web-interface to access, download and play files stored on the USB-drive
• Customizing the shared disk space by creating individual accounts
• Sharing guests to the music, but for the preservation of their personal files inaccessible
• SharePort Mobile app for iOS and Android
  - Playback of video, music and photo viewing
  - Document viewer
  - Backup Media of preservation on the device
Support for Mobile Applications
• SharePort Mobile
• QRS Mobile
• mydlink Lite
Fiziksel Özellikler
Measurements
93 x 111 x 145 mm
Weight
330 g
Temperature
From 0 to 40 C
Humidity
From 10% to 90% (non-condensing)
Certifications
• FCC Class B
• CE Class B
• C-Tick
• Wi-Fi
• Wi-Fi Multimedia (WMM)
• IPv6 Ready
• Compatible with Windows 7
1 Maximum wireless signal rate derived from standard specifications IEEE 802.11n, 802.11g, 802.11b. The data rate may differ significantly from the speed of wireless connections. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual throughput. On the range of a wireless network can be affected by environmental factors. Wireless network range and data rate are relative indicators of D-Link, based on the technical characteristics of these parameters for the product D-Link-enabled wireless standard 802.11g.Maximum throughput based on the performance of equipment D-Link with support for 802.11n.
Ürünler | Destek  | Haberler  | Hakkında |
