Hızlı Arama
Ürün Özellikleri:
Wireless 2.4 GHz (802.11n) firewall that supports VPN, WAN + 1-port 8-port LAN 10/100Base-TX
Genel Özellikler:
Fiziksel Özellikler
Hardware Version
A2
Ethernet Interface
• 1 WAN-port 10/100 Mbit / s
• 8 LAN-port 10/100 Mbit / s
Wireless Interface 1
802.11b/g/n (VSB) 2 internal omni-directional antenna with a gain of 2dBi
The USB port
1 USB 2.0 port
The console port
RJ-45
Performance 8
• Firewall Throughput 7 : 95 Mbit / s
• VPN throughput 9 : 85 Mbit / s
• The number of concurrent sessions: 20000
• The number of new sessions (per second): 200
• Firewall Policy: 200
Types of Internet connection
• Static / Dynamic IP-address
• PPPoE / L2TP / PPTP
• Multiple PPPoE
Firewall
• A static route
• Dynamic DNS
• Inter-VLAN Routing
• NAT, PAT
• Filtering web-content: Static URL-address keywords
Network
• Server / Client DHCP
• DHCP Relay
• IEEE802.1q VLAN
• VLAN (port-based)
• IP Multicast: IGMP Proxy
• IPv6 11
Wireless 2
• Multiple SSID of the wireless network (SSID)
• Service Set Identifier (SSID) to VLAN Mapping
• Standards: 802.11b/g/n
• Protect your wireless network:
  - Wired Equivalent Privacy (WEP)
  - Wi-Fi Protect Setup (WPS)
  - Wi-Fi Protected Access - Personal (WPA-PSK)
  - Wi-Fi Protected Access - Enterprise (WPA-EAP)
  - Wi-Fi Protected Access version 2 - Personal (WPA-PSK)
  - Wi-Fi Protected Access version 2 - Enterprise (WPA-EAP)
Virtual Private Network (VPN)
• VPN-tunnels: 26
• IPSec-tunnels: 10
• Customers PPTP/L2TP: 10
• GRE 1 : 5
• IPSec NAT Traversal
• Detection of non-performing units
• IP Encapsulating Security
• Payload (ESP)
• IP Authentication Header (AH)
• VPN Tunnel Keep Alive
• Hub and Spoke
Bandwidth Management
• Control the maximum bandwidth
• Management of priority bandwidth:
  - QoS based on port
  - 3 Classes
System control
• Web-user interface: HTTP, HTTPS
• Command Line
• SNMP v1, v2c, v3
Fiziksel Özellikler
Supply
External power supply 12 V DC / 1.5 A
Max. power consumption
7.44 W / 10.5 W
Measurements
208 x 118 x 35 mm
Operating temperature
From 0 to 40 ° C
Storage temperature
-20 To 70 ° C
Operating Humidity
From 5% to 95% non-condensing
EMI / EMC
FCC Class B, CE Class B, C-Tick, IC
Safety
cUL, LVD (EN60950-1)
3rd Party Certification
IPv6 Ready, Wi-Fi, a certificate ICSA, VPNC Basic Interop
MTBF
240,000 hours
1 Available in future software upgrade.
2 Only for DSR-150N/250N/500N/1000N.
3 Only for DSR-500/500N/1000/1000N.
4 The following models of 3G USB-modem: DWM-152 A1/A2/A3, DWM-156 A1/A2/A3/A5 * / A6 *, DWM-157 *, Huawei E1550, E173 and EC306. * USB-modems, marked by an "asterisk" will be supported by further updating the software.
5 Only for DSR-1000N.
6 The list of supported printers is available at URL: http://www.openprinting.org/printers.
7 VPN bandwidth testing was performed using UDP-traffic packet size 1518 bytes, in accordance with RFC2544.
8 The actual performance depends on network conditions and activated services.
9 Test VPN bandwidth performed using UDP-traffic packet size 1420 bytes.
10 Available for future software update.
11 IPv6 Ready Logo (Core) is available for DSR-500/500N and DSR-1000/1000N.
Ürünler | Destek  | Haberler  | Hakkında |
