Hızlı Arama
Ürün Özellikleri:
Wireless Wireless N 150 Router with Built-in 4-port switch, up to 150 Mbit / s
Tanımlama:
Wireless Interface
Using a wireless router DIR-300, you can quickly create a wireless network at home or in the office, which will allow your employees or members of your family to connect to a wireless network from virtually anywhere (in the range of a wireless network). The Router can serve as a base station for a wireless network device of the standards 802.11b, 802.11g and 802.11n (at speeds up to 150 Mbit / s). In the router supports multiple functions for the wireless interface. The device supports several security standards (WEP, WPA/WPA2), filtration devices to be connected by MAC-address, and allows the use of the WPS, WMM.
4-Port Switch
Built-in 4-port switch allows you to connect computers equipped with Ethernet-adapters, game consoles and other devices to your network.
Safety
Wireless Router DIR-300 is equipped with a built-in firewall. Advanced security features minimize threats of hackers and prevent intrusions to your network.
Configuration and Management
To manage and configure your wireless router DIR-300 uses a simple and user-friendly web-based interface (available in several languages).
Ürünler | Destek  | Haberler  | Hakkında |
