DME-560TEOL EOS
Tanımlama
Simultaneous Network and Modem Connections
The combo multifunction cards allow fax modem communications and network operation to be carried out at the same time. As a result, users can transfer data with other stations as well as send/receive faxes concurrently over the modem in one step. Fast 56Kbps Modem Speed The PC cards have a high-speed 56Kbps fax modem which also performs error correction and data compression.
Easy and Convenient
The combo multifunction cards let users dial into on-line services along with the ability to login to an Ethernet network. These combined functions indeed maximize the overall performance of one PCMCIA slot. And, users can definitely enjoy the convenience of another free slot! Plug and Play Installation With Windows These PC cards are compatible with Microsoft’s Plug-and-Play feature which allows the PC card installation to be simple and easy.
These PC cards are compatible with Microsoft’s Plug-and-Play feature which allows the PC card installation to be simple and easy. Users just slide the card into any PCMCIA slot and it will intelligently configure and install automatically. For users’ convenience, the PC cards are also provided with a menu driven installation program for users running in a NetWare or DOS environment. The installation program comes with a suit of diagnostic features, which provides a smooth installation process.
Wifh or Without LAN Connection
Two choices are available: (1) the DM-560 with the fax modem function only and (2) the DME-560CT with fax modem, 10BASE-T and BNC coaxial Ethernet connection. These permit users to select the model and price that suit their budget and requirement.
Market Compatibility
The PC cards come equipped with the latest 32-bit Network Operating Systems (NOS) drivers supporting popular platforms such as Windows 95, 98, NT, the Internet’s TCP/IP, Novell NetWare and others.
