DFE-530TX+EOL EOS
10/100BASE-T PCI Ethernet adapter
Tanımlama
The D-Link DFE-530TX+ is a 10/100Mbps Fast Ethernet 32bit PCI Adapter for desktops, workstations, and servers. The DFE-530TX+ supports a wide range of operating systems including Macintosh and Windows.
With support for IEEE802.3 and IEEE 802.3u standards, the DFE-530TX+ supports 10BASE-T and 100BASE-TX networks. The DFE-530TX+ utilizes auto-negotiation to automatically adjust to the highest supported transfer rates up of to 200Mbps in full duplex mode.
D-Link  's DFE-530TX+ also supports optional advanced networking support features like Wake-On-LAN and Boot ROM. Computers and operating systems that support the Advanced Configuration and Power Interface (ACPI) can remotely  wake  your PC from anywhere on the network with Wake-On-LAN. With the addition of an optional Boot ROM with PXE support, the DFE-530TX+ can support network booting of supported operating systems.
The DFE-530TX+ is a cost effective and versatile solution for a wide range of desktop connectivity environments.
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DFE-530TX+/A
Front view
İndir
Destek Merkezi
