Hızlı Arama
Ürün Özellikleri:
Wireless N300 Router with 8 LAN Ports, 3G/LTE Support, and USB Port
USB Port
The router is equipped with a USB port for connecting a USB modem, which can be used to establish connection to the Internet. In addition, to the USB port of the router you can connect a USB storage device, which will be used as a network drive, or a printer.
Wireless Interface
Using the DIR-632 device, you are able to quickly create a wireless network at home or in your office, which lets your relatives or employees connect to your wireless network virtually anywhere (within the operational range of your wireless network). The router can operate as a base station for connecting wireless devices of the standards 802.11b, 802.11g, and 802.11n (at the rate up to 300Mbps).
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, WPS, WMM.
8-port Switch
The built-in 8-port switch enables you to connect Ethernet-enabled computers, game consoles, and other devices to your network.
The wireless router DIR-632 includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
Built-in Yandex.DNS service protects against malicious and fraudulent web sites and helps to block access to adult content on children's devices.
Easy configuration and update
You can configure the settings of the wireless router DIR-632 via the user-friendly web-based interface (the interface is available in several languages).
The router itself checks the D-Link update server. If a new approved firmware is available, a notification will appear in the web-based interface of the router.
Ürünler | Destek  | Haberler  | Hakkında |
