Hızlı Arama
Ürün Özellikleri:
Broadband VPN-router Cloud
Broadband VPN-router Cloud D-Link DIR-140L is a device that combines the functions of a router, switch, 10/100 Mbit / s, VPN and firewall designed specifically for the market SOHO (Small Office, Home Office), place high demands on performance and security product, which must be made in a compact desktop enclosure. As the needs of small business network services, the key factor is the need to provide a reliable solution for network security. DIR-140L provides a high return on investment through robust security features, flexible configuration, and a high degree of protection for networks SOHO.
Customizable user interface
DIR-140L is equipped with an intuitive Web-based user interface that lets you easily configure the device and manage it.Management options settings can be carried out with administrator privileges or read / write. Using data access control levels, any authorized user can easily configure or access the management interface of the router DIR-140L.
The service mydlink network management
Broadband VPN-router supports Cloud service mydlink Cloud, which allows the user to easily access the network, regardless of its location. With the PC connected to the Internet or a mobile device equipped with iOS or Android, you can use the view of clients connected to the router, change settings, or block access to the individual clients. Home users can check the most frequently visited Internet sites their children, and for the offices the ability to monitor network activity of workers.
Advanced hardware features
DIR-140L can be connected to a cable or DSL-modem to share your high-speed Internet access. Also, the device is equipped with a 4-port 10/100 Mbit / s, which supports full duplex mode, allowing you to connect up to 4 devices with interfaces Ethernet.To extend a wired network, you need to simply add additional switches. In addition, using DIR-140L, you can create a virtual private network (VPN) and provide secure remote access to a central network through the Internet for 25 simultaneous users.
VPN Performance
For optimal VPN configuration, the router DIR-140L is equipped with a built-in VPN-client and the VPN-server, allowing you to maintain most of the required policies VPN. In this device, VPN support is implemented in hardware and manage up to 25 profiles, VPN. DIR-140L supports protocols IPSec, PPTP, L2TP and GRE in server mode, and allows you to handle the traffic pass-through. Advanced VPN configuration options include encryption with DES, the key management IKE / ISAKMP, negotiation mode Main / Aggressive and authentication support VPN, using a database of 10 internal users.
Ürünler | Destek  | Haberler  | Hakkında |
