DIR-816LEOL EOS
AC750 mydlink desteği ile dual-band kablosuz yönlendirici
Tanımlama
Dual-band wireless router with support for mydlink AC750 is an affordable and effective solution to create a wireless network that combines the characteristics of the latest technology 802.11ac, providing work in two frequency bands, and the ability to connect to the Fast Ethernet port to provide continuous network operation. Wireless AC technology provides extended wireless coverage and connection, and advanced security features - reliable protection of your network and data.
Continuous operation in two frequency bands, thanks to technology Wireless AC
Router DIR-816L provides a common wireless speed up to 750 Mbit / s and increased the range of the wireless network. This device also supports simultaneous operation in two frequency bands for maximum performance wireless network. Browse Web-page, play online and communicate with your friends using the 2.4GHz frequency, while the frequency of 5 GHz band can be used for streaming media content. Moreover, each frequency band can be operated as a separate network of Wi-Fi, allowing you to tailor the network to meet your needs. You can customize the guest area to provide visitors with access to the Internet, but at the same time keep the data available to them in the local network.
mydlink SharePort ™ - your personal cloud storage
Connect the USB-drive to the DIR-816L for the immediate establishment of a personal repository to gain remote access to the documents, movies, photos or music with mydlink SharePort. Save space on your mobile device thanks to streaming your favorite shows and music or download certain episodes or songs to your device for offline playback.
Mydlink service
DIR-816L supports cloud service mydlink, which provides the ability to remotely access, view and control the device. The service mydlink you can view information about the users who are connected to the router, change the settings to block unauthorized users from any computer or mobile platforms iOS and Android, connected to the Internet. In addition, parents can view and control the sites visited by their children.
Easy to install and configure security
Provide users share an Internet connection is not difficulty: just open the Web-browser to access the setup wizard, and follow a few simple steps. Protect your wireless network using encryption, WPA / WPA2, in a matter of minutes using the setup wizard or use technology, Wi-Fi Protected Setup (WPS), which provides a secure connection of new devices without the need to enter the settings, or create a password. In addition, the built-in firewall protects the network against malicious attacks from the Internet, and access control features allow you to restrict access to your network.
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DIR-816LA1
Back view
Front view
İndir
Destek Merkezi
