Tanımlama
D-Link, an industry leader in networking, introduces the DP-301P+ Express EtherNetworkTM Fast Ethernet Print Server. The DP-301P+ is a compact print server that allows you to share your parallel printer on an Ethernet network. Now, everyone on your network can enjoy the benefits of sharing a single printer.
The DP-301P+ is a great alternative to software-based printer sharing. The DP-301P+ eliminates the need to have your printer connected to a host computer. With the DP-301P+, everyone on your network can be sure that their printing jobs go through at any time. Documents also print faster from the DP-301P+ than from software-based printer sharing solutions.
The DP-301P+ is designed to make installation simple. It has a built-in Centronics connector that connects directly to your printer without the hassle of using a printer cable. Its compact size makes placement of the DP-301P+ easya¦?mp;euro;?even in areas with limited space.
The DP-301P+ supports all the major networking protocols such as TCP/IP, NetBEUI, AppleTalk, and EtherTalk. It is compatible with computers running Windows, Macintosh, Linux, and all other TCP/IP compatible operating systems.
The DP-301P+ is easily configured using a Web-browser. With the user-friendly Web-based setup, you can quickly configure your DP-301P+ Print Server from any computer on the network. A PSAdmin configuration program is also included to configure your DP-301P+ for Windows-based systems.
Add the DP-301P+ to your home, school, or small office network for the convenience of a shared network printer.
