DEM-424XTEOL
Module 1 Port XFP 10G (10GBASE-ER) for single mode fiber optic cable (up to 80km)
Kust osta
Kirjeldus
Transceiver D-Link DEM-424XT is designed for installation in equipment for networks 10GE, equipped with a special expansion slots. It supports standard IEEE 802.3ae 10GBASE-ER and transmits data over single mode optical fiber at distances up to 80km. The transceiver complies with the Small Form Factor Pluggable (XFP) and compatible with the Multi-Source Agreement (MSA).
Data transmission over optical fibers
This transceiver is intended for installation in equipment with slots XFP, and performs data transmission on the single mode optical fiber at a wavelength of 1550nm. It supports voltage +3.3V and +5V and is compatible with standard Multi-Source Agreement (MSA) Small Form Factor Pluggable (XFP). The transceiver includes an optical transmitter and an optical receiver circuitry. It is placed in a metal casing, which provides reliability of the device.
Wide range of applications
10 Gigabit Ethernet transceiver can be used to build high-speed optical backbones networks LAN, WAN and MAN connectivity and performance servers and data centers.
Põhiomadused
Standard
IEEE 802.3ae 10GBASE-ER 10Gigabit Ethernet
The sensitivity of the optical receiver
-23dBm (max)
Transceiver type
XFP (Small Form Factor Pluggable)
Jack
Duplex LC
Data rate
From 9.95Gbit/s to 10.7Gb/s
Wavelength
1550
Type of cable
Single-mode fiber optic cable 9/125um
The maximum cable length
80km
Füüsilised parameetrid
Supply voltage
Supported by the +3.3V and +5.0V
Operating temperature
-50 to 70°C
Storage temperature
-40 to 85°C
Humidity
From 0% to 85% relative humidity
EMI Certifications
+ FCC Class B
+ CE
Sertifikaadid
Sidustooted
DEM-424XT  Module 1 Port XFP 10G (10GBASE-ER) for single mode fiber optic cable (up to 80km)
Pildid
DEM-424XT/A
Eestvaade
Failid
Vaadake samuti
