DSM-320RDEOL EOS
Kirjeldus
The D-Link MediaLounge DSM-320RD is a wireless media player with DVD and card reader that connects your home entertainment center to your home network. It allows you to wirelessly stream music, photos and videos from the PC to your television and stereo system. Using the 802.11g wireless technology , the DSM-320RD can stream media content from your PC at a high wireless signal rate or via an Ethernet cable. Experience digital media like never before with the MediaLounge DSM-320RD Wireless Media Player with DVD and Card Reader. The DSM-320RD provides instant access to digital music, videos, and photos all from the comfort of your living room.
The DSM-320RD integrates seamlessly with your existing wired or wireless network. Using progressive scan technology, you can watch your favorite DVD in high resolution (for high-definition and HD-ready TVs) with theater-like sound. In addition to DVD, this DVD Player also plays SVCD, VCD, CD-R, DVD-RW, CD-RW, CD, and MP3 discs. The DSM-320RD features a built-in 5-in-1 card reader, which provides a convenient way to view and share digital photos, music, and videos stored on a memory card. Popular memory cards, including SD, Memory Stick, MMC, and Compact Flash (Type I and II) are supported. You can get access to thousands of songs right from your living room. With support for Windows Media Connect (WMC) music files protected by Windows Media Digital Rights Management (WMDRM) can be streamed from your PC to your living room.
Setting up the DSM-320RD is simple, and with support for Windows Connect Now, configuring the wireless settings is easier than ever before. Simply run the Wireless Network Setup Wizard from Windows XP Service Pack 2 and transfer the wireless settings to the DSM-320RD using a USB flash drive.
