DGS-1005D
5-Port 10/100/1000Base-T Switch
Description
The DGS-1005D 5 Port Gigabit Desktop Switch is economical, plug-and-play networking switch solution for SOHO and small to medium businesses. It provides the choice of five gigabit ports, enabling you to easily expand your network and quickly upgrade your connectivity. Support for IEEE 802.3az Energy-Efficient Ethernet (EEE) and IGMP Snooping for Gigabit Ethernet connection speeds provide advanced features in a compact package.
Integrated Networking
Simplified Installation
All of the ports on the DGS-1005D switch supports automatic MDI/MDIX crossover, eliminating the need for crossover cables. Each port can be plugged in directly to a server, hub, router, or switch using regular straight-through twisted-pair Ethernet ca-bles. In addition, the DGS-1005D switch features multiple front, easy-to-access Ethernet ports with LED indicators per port to easily distinguish link status.
Green Technology
The DGS-1005D switch features green technology, such as IEEE 802.3az Energy-Efficient Ethernet (EEE) and link status detection. Energy-Efficient Ethernet reduces power consumption of the switch when network utilization is low, reducing the cost of ownership during periods of inactivity. Link status detection automatically powers down ports when there is no link detected, saving power when the connected device has been shut down or disconnected.
Traffic Management
The DGS-1005D switch includes traffic management features, such as IEEE 802.1p Quality of Service (QoS) and IEEE 802.3x Flow Control. The 802.1p QoS feature allows different types of traffic to be prioritized, depending on their importance. Flow Control will temporarily stop data transmission when the switch’s input buffer is full, helping to minimize dropped packets and providing a more reliable connection for all of your connected devices.
General features
Hardware Revision
S1
R1
Hardware
Interfaces
• 5 x 10/100/1000Base-T ports
LEDs
• Power
- Solid Green – Power On
• Link/Act (per port)
- Solid Green – Connection/Link-up
- Blinking green – Data reception or transmission
Power Input
• DC Power Adapter Connector
Enclosure
• Metal
Installation
• Desktop
• Wall mounting
Functionality
Port Standards/Functions
• IEEE 802.3 10Base-T
• IEEE 802.3u 100Base-TX
• IEEE 802.3ab 1000Base-T
• IEEE 802.3x Flow Control
• Speed and duplex mode auto-negotiation for each port
• Auto MDI/MDIX adjustment for all ports
Half/Full Duplex
• Half/full-duplex for 10/100 Mbps
• Full-duplex for 1000 Mbps speeds
Features
• Green Technology: Power Saving by Link status detection
• IEEE 802.1p QoS: 4 queues
• IGMP Snooping
• Green Technology: Power Saving by Link status and Cable length detection
• IEEE 802.1p QoS: 8 queues
• IGMP Snooping
Performance
Switching Capacity
• 10 Gbps
Transmission Method
• Store-and-forward
MAC Address Table
• 2K entries
Max. Packet Forwarding Rate
• 7.44 Mpps
MAC Address Learning
• Automatic update
Packet Buffer
• 128 KB
Jumbo Frame Size
• 15 KB
• 9 KB
Physical
Dimensions
• 100 x 64 x 24 mm
• 91 x 85 x 22.4 mm
Weight
• 0.15 kg
• 0.19 kg
Power Input
• External power adapter:
- 5 V DC / 0.55 A
- 5 V DC / 1 A
• Power adapter cable: 1.2 m
Maximum Power Consumption
• 1.295 W
• 2.87 W
Standby Power Consumption
• 0.187 W
• 0.47 W
Heat Dissipation
• 1.29 W (4.4187 BTU/hr)
• 2.87 W (9.79 BTU/hr)
MTBF (hours)
• 1 116 366
• 1 479 725
Acoustics
• 0 dB
Ventilation System
• Fanless
Temperature
• Operating: 0 to 40 °C
• Storage: -40 to 70 °C
• Storage: -10 to 70 °C
Humidity
• Storage: 5% to 90% non-condensing
• Operating: 0% to 95% non-condensing
• Storage: 0% to 95% non-condensing
Certifications
• RoHS
Safety
• LVD
• LVD
• BSMI
• CCC
• EN62368-1
EMI/EMC
• CE Class B
• FCC Class B
• CE Class B
• ICES-003 Class B
• KCC
• RCM
• CCC
• BSMI
Package Content
Package Content
• DGS-1005D Switch
• Power Adapter
• Quick Installation Guide
• DGS-1005D Switch
• Power Adapter
• Wall Mounting Kit
Certificates
Order info
DGS-1005D/S1
DGS-1005D/R1
