DCS-6010LEOL EOS
Wireless N 360° Home Network Camera
Description
	The DCS-6010L Wireless N 360° Home Network Camera is a mydlink-enabled IP surveillance camera built with a fisheye lens and a 2 megapixel sensor, making it ideal for monitoring large areas with a single camera.
	360 Degree Surveillance
	The DCS-6010L uses a fisheye lens to provide incredible wide angle coverage; simply place it on a wall for a panoramic 180° view of a room, or place it on a ceiling for a full 360° view without blind spots. Distortion correction fixes the camera video so you can use ePTZ to zoom in, zoom out, and pan across your camera’s video and survey a large area easily.
	Anywhere Access with mydlink
	The Wireless N 360° Home Network Camera is mydlink-enabled, which means that you can access and configure your camera remotely, no matter where you are. See your camera’s live view through the mydlink website, or download the mydlink mobile app and view your camera directly on your iOS or Android mobile device. Keep an eye on your home while you’re at work, or check on the office when you’re out on the road; mydlink makes it all possible.
	Zero Configuration
	If you have a mydlink-enabled Cloud Router, setting up and configuring your DCS-6010L is a snap, thanks to mydlink Zero Configuration. Simply connect your camera to its power adapter and then connect your camera to your Cloud Router with an Ethernet cable - the camera will automatically be added to your account. mydlink does the hard work for you, allowing even novice users to set up and use their mydlink-enabled cameras immediately.
	A Complete, Expandable Surveillance Solution
	The DCS-6010L is a self-sufficient surveillance solution, capable of recording snapshots and video to a MicroSD card without requiring a PC or network storage device. If you want to expand your surveillance options, D-ViewCam management software is also included, giving you the ability to manage up to 32 cameras with a robust set of features, including multi-camera views and automated e-mail alerts to keep you informed of suspicious or unusual activities.
	Built for Versatility
	The DCS-6010L comes with a wealth of features that enhance its surveillance capabilities, making it ideal for any situation. A built-in microphone and speaker allow for 2-way communication or broadcasting of an alarm siren during an event. It even includes 802.11n wireless connectivity, allowing it to be placed anywhere easily without requiring cabling to be installed.
General features
	Camera Hardware Profile
	• 1/3.2" 2 megapixel progressive CMOS sensor
	• Minimum illumination: 2 lux
	• Built-in microphone and speaker
	• 10x digital zoom
	• Focal length: 1.25 mm
	• Aperture: F2.0
	• Angle of view:
	  (H) 180°
	  (V) 180°
	  (D) 180°
	Image Features
	• Configurable image size, quality, frame rate, and bit rate
	• Fisheye distortion correction
	• Time stamp and text overlays
	• Configurable brightness, saturation, contrast, and sharpness
	• Configurable motion detection windows
	Video Compression
	• Simultaneous H.264/MPEG-4/MJPEG format compression
	• H.264/MPEG-4 multicast streaming
	• JPEG for still images
	Video Resolution
	• 1600 x 1200, 1200 x 900, 800 x 600, 400 x 300 up to 15 fps recording*
	Audio Support
	• G.726
	• G.711
	External Device Interfaces
	• 10/100 BASE-TX Fast Ethernet port
	• 802.11n wireless
	• MicroSD/SDHC card slot
	Network Protocols
	• IPv6
	• IPv4
	• TCP/IP
	• UDP
	• ICMP
	• DHCP client
	• NTP client (D-Link)
	• DNS client
	• DDNS client (D-Link)
	• SMTP client
	• FTP client
	• HTTP/HTTPS
	• Samba client
	• PPPoE
	• UPnP port forwarding
	• RTP/RTSP/RTCP
	• IP filtering
	• QoS
	• CoS
	• Multicast
	• IGMP
	• ONVIF compliant
	Security
	• Administrator and user group protection
	• Password authentication
	• HTTP and RTSP digest encryption
	System Requirements for Web Interface
	• Browser: Internet Explorer, Firefox, Chrome
	Event Management
	• Motion detection
	• Event notification and uploading of snapshots/video clips via e-mail or FTP
	• Supports multiple SMTP and FTP servers
	• Multiple event notifications
	• Multiple recording methods for easy backup
	Remote Management
	• Take snapshots/video clips and save to local hard drive or NAS via web browser
	• Configuration interface accessible via web browser
	Mobile Support
	• Windows 7/Vista/XP system, Pocket PC, or mobile phone
	• mydlink mobile app for iOS and Android mobile devices
	D-ViewCam™ System Requirements
	• Operating System: Microsoft Windows 7/Vista/XP
	• Web Browser: Internet Explorer 7 or higher
	• Protocol: Standard TCP/IP
	D-ViewCam™ Software Functions
	• Remote management/control of up to 32 cameras
	• Viewing of up to 32 cameras on one screen
	• Supports all management functions in web interface
	• Scheduled motion triggered, or manual recording options
Certificates
Order info
