DWL-X8630APProject
Unified AX Dual-Band PoE Access Point
Where to buy
Description
The DWL-X8630AP Unified AX Dual-Band PoE Access Point is designed for small to medium businesses or enterprises, providing unparalleled bandwidth and flexibility for for administrators looking to deploy a medium to large scale Wi-Fi network. This AP has manageable dual-band wireless LAN options and utilizes the cutting-edge speed of Wireless AX and. Not only can the AP operate in standalone mode, it can also be centrally managed by D-Link Unified Wireless Controllers. Highly manageable and capable of blazing speeds, the Unified AX Wireless Access Point integrates seamlessly into any existing network infrastructure and can be easily scaled to meet future demands.
Wi-Fi 6
The DWL-X8630AP is the latest model of D-Link DWL Series, utilizing 802.11ax technology (also known as Wi-Fi 6). 11ax includes 1024-QAM modulation, which surpasses speed limitations in both 2.4 GHz and 5 GHz bands. OFDMA (Orthogonal Frequency Division Multiple Access) and uplink/downlink MU-MIMO (multi-user - multiple input multiple output) boosts channel capacity and efficiency, enabling more clients to access the network. The DWL-X8630 boasts up to 4 special streams with channel bandwidths up to 160 MHz (in 5 GHz, 40 MHz in 2.4 GHz). This AX3600 AP achieves 2402 Mbps PHY on 5 GHz and 1147 Mbps PHY on 2.4 GHz*. The DWL-X8630AP’s built-in 2.5 GbE PoE port unlocks the door to ‘multi-gigabit’ Wi-Fi, making AX3600 technology essential for increasing your network’s speed and bandwidth.
Greater Speed and Connectivity
The DWL-X8630AP can operate in 2.4 GHz and 5 GHz wireless bands simultaneously and provides maximum data rates of up to 1147 Mbps in 2.4 GHz band and up to 2402 Mbps in 5 GHz band*. In addition, the DWL-X8630AP supports Link Aggregation, which allows two Gigabit Ethernet ports to be linked together and act as a single port to double the available bandwidth and maximize the overall throughput of the access point.
MU-MIMO Technology
The DWL-X8630AP supports MU-MIMO (Multi-User Multiple Input Multiple Output), which enables the device to simultaneously communicate with multiple clients using multiple antennas. This allows the access point to utilize the spectrum more efficiently and significantly increase the network capacity.
Centrally Managed
When working in conjunction with D-Link Unified Controllers, the DWL-X8630AP can be centrally managed. This allows for a large number of APs to be deployed and managed easily and efficiently. Once the APs are discovered by the controller, the administrator can push the configuration to them as a group, instead of configuring each access point individually.
Easy to Install
The DWL-X8630AP can be ceiling mounted or wall mounted to meet the needs of any wireless application. For additional flexibility, this AP has integrated Power over Ethernet (PoE) support, allowing the devices to be installed in areas where power outlets are not readily available.
Advanced Wireless Features
The DWL-X8630AP supports 802.1p Quality of Service (QoS) for enhanced throughput and better performance of time-sensitive traffic like VoIP and streaming DSCP. This AP supports Wi-Fi Multimedia (WMM), so in the event of network congestion, time-sensitive traffic can be given priority ahead of other traffic. Furthermore, when a number of access points are in close proximity to each other, an access point will refuse new association requests once its resources are fully utilized, allowing the association request to be picked up by a neighboring unit, distributing the load over multiple APs. Band steering technology enables the DWL-X8630AP to intelligently place clients on the optimal wireless band to avoid congestion and allows for smooth streaming of video, seamless browsing, and fast downloads for mobile devices. Airtime Fairness ensures that equal airtime is given to each client, providing increased performance even if slower devices are connected. Fast Roaming** is also supported, which allows the wireless client to roam between access points.
General features
Interfaces
• 802.11a/b/g/n/ac/ax (Wi-Fi 6)
• 100/1000/2.5GBase-T LAN1 (PoE) port
• 10/100/1000Base-T LAN2 port
• RJ45 console port
• Factory reset button
• Power switch
• Power connector
Antenna
• Internal omnidirectional antennas
• 4 dBi for 5 GHz, 3 dBi for 2.4 GHz
Power Method
• Powered by PoE or 12 V/2.5 A
Operating Channel
• 1 to 13 channels for 2.4 GHz band (per country code)
• 36 to 165 channels for 5 GHz band (per country code)
Management Interfaces
• Web-based User Interface (HTTP/HTTPS)
• Telnet/SSH
• Command Line Interface (CLI)
• SNMP v1/v2c/v3
SSID Security
• Up to 32 SSIDs, 16 per radio
• 802.1Q VLAN
• Station Isolation
Wireless Security
• Latest 128-bit Personal wireless encryption
• Latest 192-bit Enterprise wireless encryption
• SAE
• OWE (Enhanced Open)
• AES
• TKIP
Detection & Prevention
• Rogue and Valid AP Classification
Authentication
• MAC Address Filtering
Wireless Frequency Range
• 802.11b/g/n/ax: 2.4 GHz to 2.4835 GHz
• 802.11a/n/ac/ax: 5.15 GHz to 5.825 GHz
Wireless speed
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit/s
• IEEE 802.11b: 1, 2, 5.5 and 11 Mbit/s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36 and 54 Mbit/s
• IEEE 802.11n (2.4 GHz): up to 600 Mbit/s
• IEEE 802.11n (5 GHz): up to 600 Mbit/s
• IEEE 802.11ac: up to 1733 Mbit/s
• IEEE 802.11ax: up to 2402 Mbit/s
Transmitter Output Power
• IEEE 802.11a:
  20 dBm at 6~36 Mbit/s
  18 dBm at 48 and 54 Mbit/s
• IEEE 802.11b:
  20 dBm at 1~11 Mbit/s
• IEEE 802.11g:
  19 dBm at 48 and 54 Mbit/s
• IEEE 802.11n:
  2.4 GHz:
  20 dBm at MCS0-MCS5
  19 dBm at MCS6-MCS7
  5 GHz:
  20 dBm at MCS0-MCS5
  18 dBm at MCS6-MCS7
• IEEE 802.11ac:
  VHT 80:
  18 dBm at MCS0-MCS9
  VHT 80+80:
  16 dBm at MCS0-MCS9
• IEEE 802.11ax:
  VHT 20:
  19 dBm at MCS0/1/2/3
  17 dBm at MCS4/5/6
  15 dBm at MCS7/8
  13 dBm at MCS9
  HE20:
  13 dBm at MCS10/11
  VHT 40:
  17 dBm at MCS4/5/6
  15 dBm at MCS7/8
  12 dBm at MCS9
  HE40:
  12 dBm at MCS10/11
  VHT 80:
  17 dBm at MCS4/5/6
  15 dBm at MCS7/8
  12 dBm at MCS9
  HE80:
  12 dBm at MCS10/11
Receiver Sensitivity
• IEEE 802.11a:
  -82 dBm at 6 Mbit/s
  -81 dBm at 6 Mbit/s
  -79 dBm at 12 Mbit/s
  -77 dBm at 18 Mbit/s
  -74 dBm at 24 Mbit/s
  -70 dBm at 36 Mbit/s
  -66 dBm at 48 Mbit/s
  -65 dBm at 54 Mbit/s
• IEEE 802.11b:
  -89 dBm at 2 Mbit/s
  -83 dBm at 11 Mbit/s
• IEEE 802.11g:
  -82 dBm at 6 Mbit/s
  -81 dBm at 6 Mbit/s
• IEEE 802.11n:
  2.4 GHz/HT-20:
  -82 dBm at MCS0/8/16/24
  -79 dBm at MCS1/9/17/25
  -77 dBm at MCS2/10/18/26
  -74 dBm at MCS3/11/19/27
  -70 dBm at MCS4/12/20/28
  -66 dBm at MCS5/13/21/29
  -65 dBm at MCS6/14/22/30
  -64 dBm at MCS7/15/23/31
  2.4 GHz/HT-40:
  -79 dBm at MCS0/8/16/24
  -76 dBm at MCS1/9/17/25
  -74 dBm at MCS2/10/18/26
  -71 dBm at MCS3/11/19/27
  -67 dBm at MCS4/12/20/28
  -63 dBm at MCS5/13/21/29
  -62 dBm at MCS6/14/22/30
  -61 dBm at MCS7/15/23/31
  5 GHz/HT-20:
  5 GHz/HT-40:
• IEEE 802.11ac:
  VHT 20:
  -82 dBm at MCS0
  -79 dBm at MCS1
  -77 dBm at MCS2
  -74 dBm at MCS3
  -70 dBm at MCS4
  -66 dBm at MCS5
  -65 dBm at MCS6
  -64 dBm at MCS7
  -59 dBm at MCS8
  -57 dBm at MCS9
  VHT 40:
  -79 dBm at MCS0
  -76 dBm at MCS1
  -74 dBm at MCS2
  -71 dBm at MCS3
  -67 dBm at MCS4
  -63 dBm at MCS5
  -62 dBm at MCS6
  -61 dBm at MCS7
  -56 dBm at MCS8
  -54 dBm at MCS9
  VHT 80:
  -76 dBm at MCS0
  -73 dBm at MCS1
  -71 dBm at MCS2
  -68 dBm at MCS3
  -64 dBm at MCS4
  -60 dBm at MCS5
  -59 dBm at MCS6
  -58 dBm at MCS7
  -53 dBm at MCS8
  -51 dBm at MCS9
  VHT 80+80:
  -73 dBm at MCS0
  -70 dBm at MCS1
  -68 dBm at MCS2
  -65 dBm at MCS3
  -61 dBm at MCS4
  -57 dBm at MCS5
  -56 dBm at MCS6
  -55 dBm at MCS7
  -50 dBm at MCS8
  -48 dBm at MCS9
• IEEE 802.11ax:
  VHT 20/HE20:
  -82 dBm at MCS0
  -79 dBm at MCS1
  -77 dBm at MCS2
  -74 dBm at MCS3
  -70 dBm at MCS4
  -66 dBm at MCS5
  -65 dBm at MCS6
  -64 dBm at MCS7
  -59 dBm at MCS8
  -57 dBm at MCS9
  -55 dBm at MCS10
  -53 dBm at MCS11
  VHT 40/HE40:
  -79 dBm at MCS0
  -76 dBm at MCS1
  -74 dBm at MCS2
  -71 dBm at MCS3
  -67 dBm at MCS4
  -63 dBm at MCS5
  -62 dBm at MCS6
  -61 dBm at MCS7
  -56 dBm at MCS8
  -54 dBm at MCS9
  -52 dBm at MCS10
  -50 dBm at MCS11
  VHT 80/HE80:
  -76 dBm at MCS0
  -73 dBm at MCS1
  -71 dBm at MCS2
  -68 dBm at MCS3
  -64 dBm at MCS4
  -60 dBm at MCS5
  -59 dBm at MCS6
  -58 dBm at MCS7
  -53 dBm at MCS8
  -51 dBm at MCS9
  -49 dBm at MCS10
  -47 dBm at MCS11
Physical Parameters
Dimensions
• Diameter: 220 mm
• Height: 47 mm
Weight
• 0.862 kg without bracket
• 0.883 kg with bracket
Power Supply
• External Power Adapter (not included): 12 VDC 2.5A
• Supports 802.3at PoE PD on LAN1 Port
Max Power Consumption
• 25.27 W
Enclosure
• Bottom cover - plastic
• Top cover - plastic
• UL2043 certified chassis
Temperature
• Operating: 0В° to 40В°C
• Storage: -20В° to 65В°C
Humidity
• Operating: 10% to 90% (Non-condensing)
• Storage: 5% to 95% (Non-condensing)
Certifications
• CE
• EN55032, EN55024, EN61000-3-2, EN61000-3-3, EN60601- 1-2 (Medical electrical equipment), EN301489-1
• EN301489-17, EN300328, EN301893
• FCC
• IC
• cUL+UL (UL/CSA 62368-1 + UL 60950-22)
• LVD (IEC/EN 62368-1)
• CB (IEC/EN 60950-1 + 62368-1)
• RCM
• NCC
• BSMI (CNS 14336-1)
• UL2043
* Maximum wireless signal rate derived from IEEE standard 802.11ax and 802.11ac specifications. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range.
** This feature is available when Unified AP is used in conjunction with D-Link’s line of Unified Wireless Controllers.
Certificates
Order info
DWL-X8630AP/UN/A1A
Pictures
DWL-X8630AP/A1
Front view
View from the right
Back view
Downloads
Support Resources
