DGS-3426EOL EOS
מתג מנוהל 24 פורטים +Layer2 במהירות 10/100/1000 + בנוסף 4 פורטים Combo 1000Base-T/Mini GBIC SFP ו-2 סלוטים להרחבות
תאור
The xStack® DGS-3426 by D-Link is a high-performance, managed, stackable Layer 2+ switch that provides ideal network solutions for workgroups and edge deployments. D-Link® Single IP Management (SIM) allows network administrators to cluster a virtual stack of up to 32 DGS-3426 dispersed switches through a single IP address. The clustering environment spans buildings, making it perfect for businesses that require multiple building deployment. The DGS-3426 also supports physical stacking of up to 12 units in a stack, so that the entire stack can act as a single logical unit with up to 40Gbps of stacking backplane. Furthermore, the xStack switch provides comprehensive security for edge access such as Access Control List, DHCP server screening and DoS attack prevention.
Non-Blocking Switching
The xStack DGS-3426 provides non-blocking switching solutions for gigabit connection and supports 24 gigabit ports with optional 3 10Gigabit uplinks. The switch also supports four combo SFP ports, which means that when these ports are enabled, four of the copper gigabit ports will be disabled. When stacked, the xStack DGS-3426 has a stacking backplane of 40Gbps.
Advanced Network Security
For edge network security, the DGS-3426 supports features such as IP-MAC-Port Binding to prevent security breaches such as rogue DHCP server, man-in-the-middle attacks or IP spoofing. For clients with XP SP3, Vista, or servers with Microsoft’s Server 2008, the xStack DGS-3426 works in conjunction with Microsoft’s Network Access Protection (NAP) as part of an ecosystem that enforces compliance with network health policies. The xStack switch grants network hosts access only when compliant with IT security policies, such as up-to-date anti-virus signatures and operating system patches. This prevents a virus-infested client or server from gaining access and furthering contamination.
The xStack switch also supports loopback detection, which detects a loop in the network even though the end device causing the loop is without spanning tree. When the switch detects a loop is in the connected node, the xStack DGS-3426 shuts down the port with the loop so that the entire system will continue to function normally. This feature can also be VLAN based.
The DGS-3426 incorporates advanced mechanisms to detect an attack against a switch’s central processing unit and to take corrective action on an attacking interface. When a Denial of Service attack is waged against the xStack switch, the D-Link Safeguard Engine™ detects the threat and prevents overload of the central processor, insuring network integrity and helping to maintain open network bandwidth channels.
In addition, this D-Link switch supports 802.1x authentication, which allows users to securely log on to your network. When used in conjunction with a RADIUS server, 802.1x requires each user workstation attached to the xStack switch to provide a username and password before gaining access to the network. Other security features include Access Control List, allowing an administrator to restrict network access through a variety of means including MAC address, IP, UDP/TCP, and even VLAN ID.
IP Clustering Stackable
The xStack DGS-3426 provides Single IP Management Technology (SIM), which allows a set of switches to be managed a single IP, regardless of geographical locations. Your stack can be comprised of units that are located anywhere on the network, minimizing the impact of any single point of failure. Furthermore, multiple xStack switches can be configured, monitored and maintained from any workstation running a web browser through one unique IP address. The stack is managed as a single object, with all units identified by a single IP address. Using Tree View, you can obtain an overview of the members of the stack and a network topology showing the locations of the units and their link information. This simple yet powerful web-based management eliminates the need for you to install expensive SNMP network management software. You can add units to up to 32 switches per stack not limited to any specific D-Link SIM models.
Voice and Video Applications
For today’s business, having voice, data and video on the same network is common practice. This challenge is met by the DGS-3426, which supports 802.1p with 8 queues. The administrator can designate the priority of the traffic based on a variety of means including IP or MAC address, so that voice data is always clear and jitter free. Video traffic can also be assigned with the same priority. In addition, the xStack switch provides IGMP Snooping or MLD snooping, which allows the forwarding of multicast packets such as streaming audio and video, without increasing network broadcast congestion. By snooping IGMP registration information within a frame, a list of workstations who have joined the multicast group is created. This list allows a switch to intelligently forward packets to only the appropriate member workstations. In conjunction with the 802.1Q VLANs the switch supports, Quality of Service and security can be achieved on a network infused with data traffic.
For other multimedia-on-demand applications, such as IPTV deployments, the xStack DGS-3426 provides advanced features for easy video streaming management. For example, the xStack switch supports per port multicast stream control, which allows a service provider to assign limited multicast addresses per port. This means it can act as a security control that pre-configures channels for each subscriber on a port level to prevent unauthorized multicast join. The xStack DGS-3426 also supports IGMP multicast VLAN, which eliminates duplicate multicast traffic being sent to clients in different VLANs and thus removing bottlenecks in the uplink port.
Ease of Management
The xStack DGS-3426 supports SNMP v1/2/3 so traps can be set on abnormal events and information can be polled to maximize the productivity of the network. Other standard management features also include RMON and IEEE 802.1d/w/s Spanning Tree. The user interface options include an intuitive web-based browser graphic interface or industry-standard CLI, either administration traffic can be protected through SSL or SSH encryptions
מאפיינים כללים
Interface
Ports
24 (10/100/1000 BASE-T)
Auto-Negotiation of Network Speed
Yes
Auto-MDI/MDIX
Yes
802.3x Flow Control
Yes
Slots
4 (SFP)
Open Slot for 10Gigabit Uplink Modules
2
RS-232 Console Port
1
Physical Stacking
Installable Module for Stacking
Single-Port DEM-410CX
Maximum Number of Stacking Ports Installable
2 CX4 Ports
Stacking Speed (Per Port)
20Gbps (Full-Duplex)
No. of Units Per Stack (Star Topology)
8*
No. of Units Per Stack (Ring Topology)
12
Option 10-Gigabit Uplink (Transceivers sold separately)
Single XFP Slot Module (DEM-410X)
Yes
Single CX4 Port Module (DEM-410CX)
Yes
10GBASE-SR (300 m Multi-Mode Fiber) Support
Yes
10GBASE-LR (10 km Single-Mode Fiber) Support
Yes
10GBASE-ER (40 km Single-Mode Fiber) Support
Yes
Maximum Number of 10-Gigabit Uplinks Installable
2
Performance
Switch Fabric
88Gbps
Packet Forwarding Rate
65.47Mpps
Packet Buffer
750KB
MAC Address Table
8K Entries
IP v.4 Static Routing Table
128 Entries
IP v.6 Static Routing Table
128 Entries
IP v.4 Host Table
2K Entries
IP v.6 Host Table
1K Entries
Power
Power Supply
100 to 120VAC, 200 to 240VAC, 50/60Hz, Internal Power Supply
Power Consumption (Maximum)
70.8 Watts
Optional Redundant Power Supply
DPS-500
Physical/Environmental
Heat Dissipation
241.58 BTU/Hr.
Ventilation
2 40x40 mm DC Fans
Dimensions
441 x 389 x 44 mm
Size
19-Inch Rack-Mount Width, 1U Height
Weight (Without Optional Module)
5.42 kg
Temperature
Operating: 0єC to 40єC
Storage: -10єC to 70єC
Humidity
Operating: 10% ~ 90% RH
Storage: 5% ~ 90% RH
Emissions
FCC Class A, CE, C-Tick
Safety
CSA International
Software Functions
L2 Features
IGMP snooping
Spanning Tree
802.1D STP
802.1W RSTP
802.1S MSTP
STP loop back detection
8 802.3ad Link Aggregation groups
Back Pressure Flow Control
Port mirroring
one-to-one
multiple-to-one
ACL modes
Trunking/mirroring across stack
Head-of-line blocking prevention
VLAN
802.1Q
Double VLAN
4K VLAN
GVRP
Guest VLAN
L3 Features
128 IP v.4/v.6 Static Routing
IP v.6 Tunneling
QoS (Quality of Service)
Per flow bandwidth control
802.1p support
8 queues per port
Queue handling methods
WRR
Strict
CoS based on:
Switch port
MAC address
802.1p priority
VLAN
Protocol type
TOS
DSCP
IP v.4/v.6 address
IP v.6 traffic class
IP v.6 flow label
TCP/UDP port
ACL (Access Control List)
Maximum 768 rules based on:
Switch port
MAC address
802.1p priority
VLAN
Protocol type
TOS
DSCP
IP address
IP v.4/v.6 address
IP v.6 flow label
TCP/UDP port
Time-based ACL
CPU interface filtering
Security
RADIUS/TACACS/TACACS+
SSH v.2
SSL v.3
Port security
802.1x port-based/MAC-based access control
Web-based access control
Broadcast storm control
Traffic segmentation
MAC-IP binding
Management
D-Link Single IP Management v.1.5
Web-based GUI
CLI
Web GUI traffic monitoring
Web MAC address browsing
Telnet server
TFTP client
SNMP v.1, v.2c, v.3
SNMP trap on MAC notification
RMON v.1
BootP/DHCP client
DHCP auto-configuration
DHCP relay option 82
System log
Trap/alarm/log severity control
Dual Images
Dual Configurations
CPU Monitoring
Virtual Interface
Warranty Information
Warranty
lifetime warranty
Ordering Information
Part Number
Description
DGS-3426
24 Port L2+ Gigabit Stackable Ethernet Managed Switch, 2 Option 10 Gigabit Uplinks
DGS-3426P
xStack 24-Port PoE Gigabit L2+ Switch, 4 Combo Gigabit/SFP Slots, 2 Optional 10-Gig Uplinks
DGS-3427
24-Port Gigabit L2+ Managed Switch with 3 Optional 10-Gig uplinks
DGS-3450
48-Port Gigabit Ethernet Managed Switch, 4 Combo Gigabit/SFP Slots, 2 Optional 10-Gig Uplinks
DPS-500
140Watt Redundant Power Supply Unit
תקנים
הורדות
איורים
DGS-3426/A
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
