DAP-1150/NB1EOL EOS
תאור
Wireless Interface
Using DAP-1150/NB1, you can quickly organize your wireless network and allow your employees or your family members to connect to it almost anywhere (in the range of a wireless network). The access point can serve as a base station to connect to a wireless network devices that run on standard 802.11b, 802.11g and 802.11n (with up to 150 Mbit/s).
The device provides many functions for the wireless interface. The device supports several security standards (WEP, WPA/WPA2), filter plug-in device MAC-address, and allows the use of the WPS and WMM.
Configuring and Managing
To manage and configure DAP-1150/NB1 used a simple and convenient built-in web-based interface (available in several languages).
Access Point Mode
You can use DAP-1150/NB1 as an access point to create a wireless network or connect to a wired router
Router Mode
You can connect to router mode DAP-1150/NB1 to a cable or DSL-modem or dedicated Ethernet-line to a high-speed Internet connection for a wide range of professional tasks.
Repeater mode wireless network
You can use DAP-1150/NB1 in router mode to extend the range of wireless router.
Security
In router mode DAP-1150/NB1 provides firewall. Enhanced security features allow you to minimize the effects of hackers and prevent intrusion into your network and access to undesirable Web sites for users on your network.
מאפיינים כללים
LAN interface
• 10/100BASE-TX Ethernet port with auto MDI / MDIX cross
WLAN interface
• IEEE 802.11b/g/n
Network Features
(Router Mode)
• Types of WAN-connection
- PPPoE
- Static IP
- Dynamic IP
- PPTP/L2TP + Static IP
- PPTP/L2TP + Dynamic IP
• DHCP-server and DHCP-client
• DNS relay
• VPN-Pass Tunnel (PPTP/L2TP)
• Dynamic DNS
• Static IP-routing
• Remote Access
• Network statistics for each interface
• IGMP Proxy
• RIP
• UPnP
Wireless connection
• The segmentation of the wireless network (up to 4 SSID)
• Supported security standards
- WEP
- WPA/WPA2 Personal
- WPA/WPA2 Enterprise
• MAC-filter
• Management of connected devices
• PIN and PBC methods WPS function
• The WMM (Wi-Fi QoS)
• Advanced Settings
• The "client" - work as a repeater wireless network (router mode)
Firewall Features
(Router Mode)
• Monitor status of network connections (SPI)
• IP-filters
• URL-filter
• MAC-filter
• DMZ-zone
• The anti-ARP-and DDoS-attacks
• Virtual Servers
• Web-based configuration and management in multiple languages
• Access to TELNET
• Update the internal device software through the web-interface
• Save and load configuration
• Support for remote logging
• Automatic synchronization of system time from NTP-server
Indicators
• Power
• LAN / WAN
• WLAN
