DSL-2540U (ANNEX B)EOL EOS
תאור
Affordable high-speed connectivity for home and small office
Router ADSL2 + DSL-2540U/BRU/C3B - an affordable, high-performance device for home and small office. Through the use of standard ADSL2 / 2 + speeds up to 24Mbps downstream / s, media QoS, advanced features of the firewall and integrated 4-port switch, this router allows you to organize safe and high-speed Internet connection for your home or small office.
Advanced firewall features to ensure safe operation of the Internet
The security features allow you to prevent unauthorized access by malicious users to your home and office network through the Internet. DSL-2540U/BRU/C3B provides firewall security using Stateful Packet Inspection SPI, keep the minutes of hacker attacks such as Denial of Service - DoS. Before sending data to the internal SPI inspects the contents of all incoming packet headers. Access control is provided with packet filtering based on MAC / IP-address of the source and receiver.
Functional QoS to ensure good transmission quality
The router supports multiple priority queues for groups of home and office users, providing a reliable connection for data transfer and enabling to avoid problems with traffic congestion. QoS support allows more efficient data transfer applications that are sensitive to delays, such as VoIP, streaming multimedia and on-line games on the Internet.
מאפיינים כללים
Interfaces
• 1 ADSL port with RJ-11
• 4-port 10/100BASE-TX Ethernet LAN with RJ-45 auto-sensing MDI / MDIX cross
ADSL standards
• ADSL: ANSI T1.413-1998 Issue 2; ITU G.992.1 Annex B
• ADSL2: ITU G.992.3 Annex B
• ADSL2 +: ITU G.992.5 Annex B
The device is compatible only with Annex B lines
ADSL data rate
• G.dmt: 8Mbps / s downstream, 832Kbit / s upstream.
• G.lite: 1.5Mbit / s downstream, 512Kbit / s upstream.
• ADSL2: 12Mbit / s downstream, 1Mbit / s upstream
• ADSL2 +: 24Mbps / s downstream, 1Mbit / s upstream
ATM / PPP
• Multiprotocol encapsulation over AAL5
• Encapsulation of Ethernet Bridged and routed
• Multiplexing-based LLC and Virtual Channel (VC-based multiplexing)
• ATM Forum UNI3.1/4.0 PVC
• Format of the cell ATM ITU-T Rec.I.361
• PPP over Ethernet (PPPoE)
• PPP over ATM
• PPP Link Control Protocol (LCP)
• Internet Protocol Control Protocol (IPCP)
• Authentication Protocol PPP (PAP)
• PPP Challenge Handshake Authentication Protocol (CHAP)
• Microsoft PPP CHAP
Network Protocols
• Ethernet to ADSL Self-Learning Transparent Bridging
• Internet Control Message Protocol (ICMP)
• Network Address Translation (NAT), static IP-routing
• NAT ALG (optional): MSN / AOL / Yahoo Messenger, FTP, CUSEEME, Real Audio, MIRC, SIP, ICQ, games.
• Dynamic Host Configuration Protocol (DHCP): DHCP-server/klient/relay
• SNTP, DNS Relay, DDNS Proxy and IGMP Proxy
Firewall / Access Security
• MAC-address filtering
• Packet filtering (IP / ICMP / TCP / UDP)
• Prevent DoS attacks
• Intrusion detection and logging
• User Authentication PAP
• User Authentication CHAP
VPN
Multiple IPSec/PPTP/L2TP pass-through
Configuration / Management
• Easy to use Setup Wizard
• Web-based management
• 3 levels of user accounts to local / remote control
• Download the software via Web-interface / TFTP, loading / saving configuration
• TFTP-server/klient
• Prevent unauthorized software updates via the user interface, TFTP, TR-069
• Implementation of the settings via Telnet / SSH (optional)
• Local access via console (optional)
• Auto Fallback
• Automatic detection of VPI / VCI
• Manual selection ADSL/ADSL2 / ADSL2 +
• Save and restore configuration
• Diagnostics
• Log & Trace
• MIB-I, MIB-II option
• TR-069 (ACS optional)
QOS
• Prioritization / Classification of traffic
• Prioritization based on ports
• 8 priority 802.1p / q
• DiffServ-Codepoint IPQoS (ToS)
• Priority of applications based on ports
• User-defined priorities (TCP / UDP / ICMP)
• 4 priority queues on PVC
• Traffic Shaping
• Bandwidth control (64K, 128K, 256K, 512K)
• PVC / VLAN
• IGMP Snooping
