תאור
The D-Link DP-G321 Wireless Multi-Port Print Server, features two USB 2.0 ports and one parallel port. With its multiple ports, the DP-G321 allows everyone on the network to access and share up to three printers.
The DP-G321 is equipped with two USB 2.0 ports for connecting to the latest printers available on the market today, while remaining backwards compatible with USB 1.1/1.0 printers. The DP-G321 also includes a parallel port for connecting legacy parallel printers. Setup is easy using any Web browser or using the Windows configuration program PSAdmin.
The DP-G321 is IEEE 802.11g compliant, for wireless transfer speeds up to 54Mbps**, and supports both Infrastructure and Ad-Hoc wireless modes. With the DP-G321, you now have the ability and convenience of sharing printers beyond a wired network. The DP-G321 supports TCP/IP, NetBEUI and AppleTalk/ EtherTalk network printing protocols, giving you more networking options.
The DP-G321 features support for the Internet Printing Protocol (IPP), which makes your printer available online for receiving print jobs from anywhere via the Internet or your Intranet.
The DP-G321 Multi-Port Wireless Print Server is the ideal network printing solution for small offices, home offices, schools and other businesses that require sharing multiple printers.
Maximum wireless signal rate based on IEEE Standard 802.11g specifications. Actual data throughput will vary. Network conditions and environmental factors lower actual data throughput rate
מאפיינים כללים
Main features
Share Multiple Printers on Your Network
Remote Printing Support
Ports
Two USB 2.0 Ports and One Parallel Port
Encryption
WPA-PSK supported with latest firmware
Interface
Lan Interfaces: 802.11g wireless LAN
1 x 10/100BASE-TX port
Wireless Range
Operating Range: Indoors -100 meter. Outdoor - 400 meters
Operating System supported
Windows 98, ME,2000,XP, MacOS Ether Talk, Unix, Net Ware 5.0 or above (Native NDS), lpd.
