DCS-6110EOL EOS
Fixed dome network camera
Description
POWERFUL SURVEILLANCE
D-Link’s DCS-6110 is a high-performance fi xed dome Network camera, ideal for home or business. Dome type cameras are very popular in CCTV system. DCS- 6110 targets entry level market. The VGA Progressive CMOS technology delivers exceptional picture quality. Use D-Link's SoC (system-on-chip) products to provide high quality real-time video compression in MPEG-4 and Motion JPEG formats. DCS-6110 supports simultaneous dual-streaming for live monitoring and recording. With the free-bundled 32-channel recording software, the DCS-6110 is an ideal solution for high quality viewing and reliable recording. With a built-in Samba client for NAS, the DCS-6110 Network camera does not need a direct connection to a PC or any other hardware or software to capture and transfer images.
SHARP IMAGE MONITORING FROM DIFFERENT ANGLES
The DCS-6110 is recommended for indoor ceiling mounting, and thus prevents possible damage that may be caused by a burglar. This Network camera has a built-in three axis mechanism for wall mount installation. The DCS-6110 provides high quality real-time videos in MPEG-4 and JPEG compression with VGA/ QVGA/QQVGA resolution. It is suitable for narrow space surveillance, like an elevator.
VIEW LIVE VIDEO FROM A 3G MOBILE PHONE1
The live camera feed of the camera can be pulled from the 3G cellular network by using a compatible cell phone or PDA with a 3G video player. Anywhere within the 3GPP service area, users are offered a fl exible and convenient way to remotely monitor a home or offi ce in real time.
WIRED & PoE ACCESS
For effective surveillance in and around a building, this camera comes with a built-in 802.3af compliant Power Over Ethernet (PoE) module, which eases the installation process and also gives you the freedom to place the camera where it's needed. In addition, the 10/100BASE-TX Ethernet port is also provided for convenient connection to an Ethernet network or to a broadband Internet via a gateway router. The camera can be accessed and viewed from any network place as a device on the network.
SMART & EASY TO USE
The software allows you to view up to 32 cameras on a single computer screen at one central location. Users can set up automated e-mail alerts to be instantly informed of unusual activities. Fixed dome cameras usually uses fi xed focus lens, but the DCS-6110 also has a vari-focal lens. Vari-focal lens provides easier installation process because the board lens of dome camera is not like CS/C mount lens, it is not changeable. Drop ceiling bracket is another alternative option for an installation method. In addition, this Network camera supports the Universal Plug-n-Play feature, which allows computers running on Windows 2000/XP/Vista to automatically recognize the camera and adds it to the network. Sign up with one of the free Dynamic DNS services available on the web, to assign a name and domain to the camera (e.g. mycamera.dlinkddns.com). This allows users to remotely access the camera without having to remember the IP address.
General features
NETWORK PROTOCOL SUPPORT
+ TCP/IP, RTSP, RTP, RTCP, HTTP, SMTP, FTP, NTP, DNS, DHCP, UPnP, DDNS, PPPoE, ICMP, Samba client, IP Filtering, 3GPP
BUILT-IN NETWORK INTERFACES
+ 10/100BASE-TX Ethernet port
VIDEO ALGORITHM SUPPORT
+ JPEG for still image
+ MPEG4/MJPEG dual format compression
VIDEO RESOLUTION
+ Up to 30fps at 176 x 144
+ Up to 30fps at 320 x 240
+ Up to 30fps at 640 x 480
VIDEO FEATURES
+ Adjustable image size and quality
+ Time stamp and text overlays
+ 3 confi gurable motion detection windows
+ Flip & mirror
VIDEO BIT RATE
20K to 4M
CAMERA SPECIFICATIONS
+ VGA Progressive CMOS Sensor
+ 1.5 Lux @ F1.4
+ Electronic rolling shutter
+ 3.7-12mm vari-focal lens, F1.4-F2.8
LAN
+ IEEE 802.3 compliance
+ IEEE 802.3u compliance
+ Support Full-Duplex operations
+ 802.3x Flow Control support for Full-Duplex mode
+ Supported IEEE 802.3af standard (PoE)
PHYSICAL & ENVIRONMENTAL
DIAGNOSTIC LED
2 color LED
3-AXIS ANGLE
X : 350°, Y : 45°, Z : 350°
POWER INPUT
100-240VAC, 50/60Hz, 12VDC, 1.25A
POWER CONSUMPTION
Max 3.6 W
DIMENSIONS
194 (W) X 180 (D) X 107 (H) (mm)
WEIGHT
630 gm
SECURITY
+ Administrator and user group protected
+ Password authentication
SURVEILLANCE SOFTWARE FUNCTIONS
+ Remote management/control of up to 32 cameras
+ Viewing of up to 32 cameras on one screen
+ Supports all management functions provided in web interface
+ Scheduled motion triggered, or manual recording options
REMOTE MANAGEMENT
+ Confi guration accessible via web browser
+ Take snapshots/video clips and save to local hard drive or NAS via web browser
SURVEILLANCE
(Motion detection weekly schedule)
+ Upload snapshots/video clips via email
+ Upload snapshots/video clips via FTP
SYSTEM REQUIREMENTS
+ Operating System: Microsoft Windows 2000, XP, Vista
+ Browser: Internet Explorer, Firefox, Netscape, Mozilla, Opera
SUPPORTED PDA, MOBILE PHONES & SOFTWARE
Handsets with 3GPP player
+ Packet Video Player 3.0
+ QuickTime 6.5
+ Real Player 10.5
+ Windows 2000, XP
OPERATION TEMPERATURE
0º to 40º C (32º to 104º F)
STORAGE TEMPERATURE
-20º to 70º C (-4º to 158º F)
HUMIDITY
20% to 80% non-condensing
EMISSION (EMI), SAFETY & OTHER CERTIFICATIONS
+ FCC
+ CE
+ C-Tick
PACKAGE INCLUDES
+ DCS-6110 camera
+ External power adapter
+ Cat5 Ethernet cable
+ Quick Installation Guide
+ Master CD
Certificates
Order info
Pictures
DCS-6110/A
Front view
Downloads
Support Resources
