DHP-308AVEOL EOS
Mini Adapter PowerLine AV +
Tanımlama
Mini Adapter PowerLine AV + DHP-308AV compliant with HomePlug AV and use existing home electrical wiring to create a network or extend your existing network. 1 This adapter is connected to a power outlet, allows access to digital media devices, game consoles, print servers, computers and network storage devices throughout your home.
PowerLine AV + technology for applications that require high bandwidth
PowerLine AV + technology enables data transmission at speeds of over 200 Mbit / s, ie, at a higher speed compared to conventional devices PowerLine AV. This makes the device an ideal solution for applications that require high bandwidth, which guarantee the streaming of HD video, the work of VoIP-telephony and online gaming without delay. DHP-308AV provides wide bandwidth, allowing users of technology "digital home" use existing electrical wires to transmit high-quality streaming media.
Easy installation and safety
DHP-308AV plugs directly into a power outlet and does not require additional cables. Expand your home network by connecting multiple devices from the most distant points of the house, or create additional connection by connecting a switch or wireless access point to the adapter. For ease of installation encryption key can be quickly configured with the click of a button. The adapter supports 128-bit AES encryption to protect your network from unauthorized connection to the line. With simple installation Plug-and-Play, DHP-308AV adapter is the perfect solution to create a home network.
The power save function
DHP-308AV supports power saving mode to comply with European Directive on the use of energy-using products (EuP). If within a period of time not being transmitted or received, the adapter automatically switches to standby mode, reducing power consumption by more than 70%, and providing automatic energy savings without sacrificing performance.
QoS
QoS Mechanism analyzes and distributes traffic DHP-308AV into multiple data streams. It provides streaming HD video, IP-TV work (IPTV) and online gaming without further delay as priority is given to data flows automatically the most demanding quality of service.
Starter kit PowerLine AV + DHP-309AV
DHP-308AV adapter is also available in a set, which provides a complete solution PowerLine. Starter kit PowerLine AV + DHP-309AV includes two mini-adapter, DHP-308AV, allowing you to create a home network PowerLine.
