DES-3528PEOL EOS
Kirjeldus
The DES-3528/3552 xStack series are enhanced L2+ access stackable switches designed to connect end-users in a secure SMB (small and medium size business) or enterprise network. These switches provide physical stacking* , static routing* , multicast and enhanced security, making it an ideal access layer solution. The DES-3528/3552 xStack Series can seamlessly integrate with L3 core switches to form a multi-level network structure consisting of a high-speed backbone and centralized servers.
Flexible & Cost-Effective Ethernet Stack. The DES-3528/3552 series provide the option of 24 or 48 10/100Mbps Ethernet ports and up to four Gigabit uplinks per switch. Users requiring connections to devices such as IP phones, network cameras and wireless APs can deploy the DES-3528P, which provide 24 10/100Mbps PoE ports. Eight of these PoE ports provide up to 30watts per port, while the remaining adhere to the 802.3af standard (15.4watt output per port), giving administrators the ability to connect to the 802.3af standard devices as well as the 802.3at pre-standard equipment such as the 802.11n AP. The two combo 10/100/100BASE-T SFP slots on the front panel provide flexible copper or fiber Gigabit connection. The two 10/100/1000BASE-T ports on the back panel are designed for fexible dual usage. They can be used either as stacking ports with 4Gbps bidirectional stacking bandwidth, or can simply be used as copper Gigabit uplinks. Physical stacking* capability allows administrators to add up to eight switch units per stack on a scalable expansion basis. This series offers an attractive stackable switch alternative to the expensive chassis-based solution.
Comprehensive Security. The DES-3528/3552 series provide users with the latest security features such as 802.1X Guest VLAN, MAC-based Access Control (MAC) and Web-based Access Control (WAC). 802.1X Guest VLAN is a comprehensive end-point security solution for user authentication/authorization and WAC guarantees granular network access control with a user-friendly authentication mechanism. The IP-MAC-Port Binding feature allows administrators to bind a source IP address with an associated MAC and also to define the port number to enhance user access control. And with DHCP Snooping feature, the switch automatically learns the IP/MAC pairs by snooping DHCP packets and saving them to the IMPB white list. This keeps the network secure and auditable. The D-Link Safeguard Engine identifes and prioritizes "CPU interested" packets to prevent malicious traffc from interrupting normal network fows and protects switch operation.
Enhanced Network Performance & Availability. The DES-3528/3552 series targets SMB/enterprise customers who require a high level of network security and maximum uptime. It offers Static Route*, 4K VLAN, advanced selective Q-in-Q, as well as delivering progressive QoS capability for mission-critical applications and multicast services. The switches offer superior performance and availability through the latest Spanning Tree protocol, optional redundant power, and Loopback Detection (D-Link's advanced technology for preventing loops without the presence of STP).
User-friendly & Ecosystem-friendly. The DES-3528/3552 series uses D-Link's Web GUI 2.0, an easy-to-use web interface, and confguration wizards to minimize administrators' learning curve and make deployments easier to plan and implement. Utilizing the latest generation of chipsets, the DES-3528/3552 series optimizes power consumption to reduce energy costs and contribute to a greener environment. In addition, its fanless design ensures quiet operation, ideal for deployment in open spaces.
* Physical Stacking and Static Route are planned for future releases
Põhiomadused
Liidesed
+ 24 x 10/100BASE-TX porti
+ PoE toetus 10/100 BASE-TX portidel
+ 2 stack porti 10/100/1000Base-T
+ 2 kombo-porti 10/100/1000BASE-T/SFP
+ MDI/MDIX
+ Gigabit ja 100BASE-FX (kiudoptika) SFP-pordid
+ Konsoolport RS-232
Toide
+ Sisene toiteallikas: AC-DC
+ Toide väljundil: 100~240 vahelduvvool, 6.3 А (max.), 50/60 Hz
+ Toide väljudnil: 50 V alalisvool, 7,5 A (max), 12 V alalisvool, 1,4 A (max.)
+ Toide väljundil (PoE pordid): 30 W (max) pordid (1-8), 15,4 W (max.) pordid (9-24)
+ Tarbitav võimsus: 505,1 W (max.)
+ PoE tarbitav võimsus: 370W (max)
+ Varutoiteallikas: DPS-600
Tootlikkus
+ Kommutaatori läbilaskevõime: 12,8 Gbit/s
+ 64-baitise paketide maksimaalne edastuskiirus: 9.5 Mpps
+ MAC-aadressite tabeli suurus: 16 K kirjet
Indikaatorid
+ Kiirus 10/100 Mbit/s (Ethernet pordid)
+ Kiirus 10/100 Mbit/s või 1000 Mbit/s (Gigabit Ethernet pordid)
+ Link/Activity
+ Power, Console, RPS
Tarkvara funktsioonid
Stack
+ Virtuaalne stack:
- D-Link Single IP Management (SIM)
- Kuni 32 seadet, stack-i ühendatud
2.kihi funktsioonid
+ MAC-aadressite tabel: kuni 16 K kirjet
+ Voojuhtimine:
- Voojuhtimine 802.3х
- Blokeerimise ennetamine HOL
+ Jumbo-freimide toetus kuni 9 216 baiti
+ Spanning Tree Protocol:
- 802.1D STP
- 802.1w RSTP
-802.1s MSTP
- BPDU-paketide filtreerimine
+ Loopback Detection (LBD)
+ Kanalite agregeerimine 802.3ad:
-Kuni 8 gruppi seadme kohta, kuni 8 porti gruppi kohta
+ Portide peegeldamine:
-One-to-One režiim
-Many-to-One režiim
-Flow-based režiim (Voo põhine peegeldamine)
2.kihi multicast
+ IGMP Snooping:
-IGMP v1/v2/v3 Snooping
-256 gruppi toetus
-IGMP Snooping Fast Leave
+ Multicast piiramine IP-aadressi järgi (IGMP-filtreeriimine):
-Kuni 24 IGMP filtreerimis profiili, 128 aadressite diapasooni profiili kohta
+ MLD Snooping:
-MLD v1/v2 Snooping
-256 gruppi toetus
-MLD Snooping Fast Leave
VLAN
+ VLAN gruppi:
-VLAN gruppide maksimaalne arv: 4 K
+ GVRP:
Maksimaalselt 256 dünaamilist VLAN gruppi
+ 802.1 Q Tagged VLAN
+ VLAN põhineb
+ 802.1v VLAN protokoll
+ Double VLAN (Q-in-Q):
-Port-based Q-in-Q
-Selective Q-in-Q*
+ VLAN Translation
+ MAC-aadressi põhine VLAN
+ ISM VLAN
+ Assümeetriline VLAN
QoS
+ 802.1p Quality of Service
+ 8 järjekorda pordi kohta
+ Järjekordade töötlemine
-Strict Priority
-Weighted Round Robin (WRR)
-Strict + WRR
+ CoS põhineb:
-Kommutaatori port
-VLAN ID
-Järjekordade prioroteetsus 802.1p
-MAC-aadress
-IPv4/v6-aadress
-DSCP
-Protokolli tüüp
-IPv6 liikluse klaass
-TCP/UDP pordi number
-Paketi sisu
+ Toetatavad protokolli võimalused:
-Prioriteetsusele märgendi lisamine 802.1p
-TOS/DSCP märgendi lisamine
-Läbilaskeriba juhtimine
-Committed Information Rate(CIR), sammuga 64 Kbit/s
+ SRED Congestion Control
+ Voojuhtimine:
- pordipõhine (Ingress/Egress, min smmuga 64 Kbit/s)
- voopõhine (Ingress/Egress, min. sammuga 64 Kbit/s)
+ Ajapõhine QoS
Pääsuloend (ACL)
+ Kuni 768 reeglit
+ ACL põhineb:
-Prioriteetsuse jäejekord 802.1p
-VLAN ID
-MAC-aadress
-Ether tüüp
-IPv4/IPv6 aadress
-DSCP
-Protokolli tüüp
-IPv6 liikluse klass
-IPv6 voo märgised
-paketi sisu
+ACL statistika
+Ajapõhine ACL
+CPU Interface Filtering
Turvalisuse funktsioonid
+ SSH v2
+ SSL v1/v2/v3
+ Port Security funktsioon (pordipõhine turvalisus):
-Kuni 64 MAC-aadressi pordi kohta
+ Broadcast/multicast/monocast tormi juhtimine
+Liikluse segmentimine
+IP-MAC-Port Binding (IMPB) funktdioon:
-ARP-paketide kontrollimine
-IP-paketide kontrollimine
-DHCP Snooping
-500 kirjet seadme kohta
+ D-Link Safeguard Engine funktsioon
+ NetBIOS/NetBEUI filtreerimine
+ DHCP Server Screening
+ DHCP-kliendi filtreerimine
+ BPDU rünnakutest kaitse
Autentimine, autoriseerimine, kasutajatunnuste pidamine
+ 802.1X:
-Pordipõhine ligipääsu juhtimine
-MAC-aadressi põhine ligipääsu juhtimine
-Dünaamiline VLAN omistamine
+ Web põhine ligipääsu juhtimine (WAC):
-Pordipõhine voojuhtimine
+ MAC-aadressi põhine ligipääsu juhtimine (MAC):
-Hosti põhine ligipääsu juhtimine
+ Jaapani Web-juhtimisliides (JWAC)
+ Guest VLAN
+ Microsoft® NAP toetus
+ RADIUS kasutajatunnuste pidamine
+ Autentimine kommutaatori ligipääsu tagamiseks RADIUS/TACACS+
+ Kasutajatunnused: 3 taset
Juhtimine
+ Web-liides
+ Käsurealiides (CLI)
+ Telnet server
+ TFTP klient
+ ZModem
+ SNMP v1/v2/v3
+ System Log
+ RMON v1:
- 1, 2, 3, 9 gruppide toetus
+ RMON v2
-ProbeConfig group toetus
+ LLDP
+ BootP/DHCP-klient
+ DHCP automaatne seadistamine
+ DHCP Relay
+ DHCP Relay Option 82
+ PPPoE Circuit-ID märgendi lisamine
+ DHCP-server
+ Dual Image
+ Dual Configuration
+ CPU monitooring
+ NTP/SNTP
+ Parooli taastamine
+ Parooli krüpteerimine
MIB
+ RFC1213 MIB-II
+ RFC1493 Bridge MIB
+ RFC1907 SNMPv2 MIB
+ RFC1757, 2819 RMON MIB
+ RFC2021 RMONv2 MIB
+ RFC1643, 2358, 2665 Ether-like MIB
+ RFC2674 802.1p MIB
+ RFC2233, 2863 IF MIB
+ RFC2618 RADIUS Authentication Client MIB
+ RFC2620 RADIUS Accounting Client MIB
+ RFC2925 Ping & TRACEROUTE MIB
+ D-Link Private MIB
IETF® standardid
+ RFC768 UDP
+ RFC783 TFTP
+ RFC791 IP
+ RFC792 ICMP
+ RFC793 TCP
+ RFC826 ARP
+ RFC854 Telnet
+ RFC951, 1542 BootP
+ RFC2068 HTTP
+ RFC2138 RADIUS
+ RFC2139, 2866 RADIUS Accounting
+ RFC2474 DiffServ
+ RFC2597 DSCP AF
+ RFC2598 DSCP EF
+ RFC1492 TACACS
+ RFC1157 SNMPv1
+ RFC1901, 1908 SNMPv2c
+ RFC2570, 2575 SNMPv3
+ RFC3164, 3195 Syslog
+ RFC3046 DHCP Relay Option
Sertifikaadid
Sidustooted
DES-3528P xStack hallatav 2+ kihi kommutaator 24 x 10/100BASE-TX pordiga + 2 kombo-porti 10/100/1000BASE-T/SFP + 2 x 10/100/1000BASE-T porti
Lisatransiiverid
DEM-310GT SFP 1000BASE-LX transiiver, SMF, maksimaalne vahemaa kuni 10 km, 3.3 V
DEM-311GT SFP 1000BASE-SX transiiver, MMF, maksimaalne vahemaa kuni 550 m, 3.3 V
DEM-312GT2 SFP 1000BASE-LX transiiver, MMF, maksimaalne vahemaa kuni 2 km, 3.3 V
DEM-314GT SFP 1000BASE-LH transiiver, SMF, maksimaalne vahemaa kuni 50 km, 3.3 V
DEM-315GT SFP 1000BASE-ZX transiiver, SMF, maksimaalne vahemaa kuni 80 km, 3.3 V
DEM-210 SFP 100BASE-FX, SMF transiiver, maksimaalne vahemaa kuni 15 km, 3.3 V
DEM-211 SFP 100BASE-FX transiiver, MMF, maksimaalne vahemaa kuni 2 km, 3.3 V
SFP (WDM) lisatransiiverd
DEM-330T SFP 1000BASE-LX transiiver, SMF, maksimaalne vahemaa kuni 10 км, 3.3В, WDM (Tx: 1550 nm, Rx: 1310 nm)
DEM-330R SFP 1000BASE-LX transiiver, SMF, maksimaalne vahemaa kuni 10 km, 3.3 V, WDM (Tx: 1310 nm, Rx:1550 nm)
DEM-331T SFP 1000BASE-LX transiiver, SMF, maksimaalne vahemaa kuni 40 km, 3.3 maksimaalne vahemaa kuni, WDM (Tx: 1550 nm, Rx: 1310 nm)
DEM-331R SFP 1000BASE-LX transiiver, SMF, maksimaalne vahemaa kuni 40 km, 3.3 maksimaalne vahemaa kuni, WDM (Tx: 1310 nm, Rx:1550 nm)
Varutoiteallikad
DPS-600 Varutoiteallikas 500 W
DPS-800 Šassii 2-pesaga
DPS-900 Šassii 8-pesaga
