DES-1210-28P
28-pordiline PoE-ga Web Smart lüliti
Kust osta
Kirjeldus
The DES-1210 Series is the latest generation of D-Link Web Smart switches. Equipped with 24 or 48 10/100 Mbps ports, 2 10/100/1000BASE-T ports, and 2 combo 10/100/1000BASE-T/SFP ports, the DES-1210 Series integrates advanced management and security functions for enhanced performance and scalability. The DES-1210-08P/28P are built with 10/100 Mbps ports that are PoE-enabled, offering ease-of-use and green features such as Time-based PoE, which can shut off PoE power at a predetermined time. The Smart Fan feature on the DES-1210-28P allows the built-in fans to automaticallyturn on at a certain temperature, providing continuous, reliable, and eco-friendly operation of the switch. Compliant with 802.3af and 802.3at, the DES-1210-28P is capable of feeding power of up to 30 watts to devices. Management options include SNMP, Web Management, SmartConsole Utility, and Compact Command Line for easy deployment. The DES-1210 Series provides a complete and affordable solution that is ideal for small and medium businesses and the enterprise edge.
Seamless Integration
The Web Smart switches are designed to provide SMB users with complete control over their network. With Ethernet and Gigabit copper ports capable of connecting to existing CAT5 twisted-pair cables, these switches eliminate the need for complex reconfiguration. The DES-1210 Series allows for flexible connection to a backbone or server. Additionally, all ports support auto-negotiation of MDI/MDIX crossover, eliminating the need for crossover cables or uplink ports.
Extensive Layer 2 Features
Equipped with a complete lineup of L2 features, these switches include IGMP Snooping, Port Mirroring, Spanning Tree, and Link Aggregation Control Protocol (LACP). IEEE 802.3x Flow Control allows servers to directly connect to the switch for reliable data transfer. At 2000 Mbps full-duplex, the Gigabit ports provide high-speed data pipes to servers with minimum data transfer loss. Network maintenance features include Loopback Detection and Cable Diagnostics. Loopback Detection is used to detect  loops created by a specific port and automatically shuts down the affected port. Cable Diagnostics allow network administrators to quickly examine the quality of the copper cables and also determine the type of cable error.
QoS & Bandwidth Control
The DES-1210 Series switches support Auto Surveillance VLAN (ASV) and Auto Voice VLAN for VoIP and video surveillance deployments. ASV ensures the quality of real-time video for monitoring and control without compromising the transmission of conventional network data. DSCP markings on Ethernet packets enable different levels of service to be assigned to network traffic. In addition, with Bandwidth Control, network administrators can reserve bandwidth for important functions that require more bandwidth or require high priority.
Secure Your Network
D-Link’s innovative Safeguard Engine protects against traffic flooding caused by virus attacks. These switches also support 802.1X port-based authentication, allowing the network to be authenticated through external RADIUS servers. In addition, the Access Control List (ACL) feature enhances network security and protects the internal IT network. The DES-1210 Series supports ARP Spoofing Prevention, which prevents the network from being cut off or eavesdropped by hackers using faked ARPs that pretend to be PCs, servers, routers, or gateways. For added security, DHCP Server Screening screens rogue DHCP server packets from user ports to prevent unauthorized IP assignment.
Versatile Management
This new generation of Web Smart Switches provides growing businesses with simple and easy management of their network by using an intuitive SmartConsole utility and a web-based management interface that enables administrators to remotely control their network down to the port level. The SmartConsole allows customers to easily discover multiple D-Link Web Smart Switches within the same L2 network segment. With this utility, users do not need to change the IP address of their PC and it also provides an easy setup of the Smart Switches.  Switches within the same L2 network segment that are connected to the user’s local PC are displayed on screen for instant access. This allows for extensive switch configuration settings and basic configuration (password changes and firmware upgrades) of discovered devices.
The DES-1210 Series supports D-View 6.0 and Compact Command Line Interface (CLI) control through Telnet. D-View 6.0 is a Network Management System that allows for central management of critical network characteristics and provides a useful set of tools for network administrators who want to effectively manage device configurations, fault tolerance, performance, and security. CLI management of switches is possible via Telnet, and allowing administrators to perform basic operations such as password changes, firmware upgrades, and configuration file uploads.
Põhiomadused
Üldinfo
Pordi standardid ja funktsioonid
+ IEEE 802.3 10BASE-T Ethernet (keerdpaar-vaskkaabel)
+ IEEE 802.3u 100BASE-TX kiire Ethernet (keerdpaar-vaskkaabel)
+ IEEE 802.3ab 1000BASE-T Gigabit Ethernet (keerdpaar-vaskkaabel)
+ IEEE 802.3z Gigabit Ethernet (kiudkaabel) ANSI/IEEE 802.3
+ Automaatne kooskõlastamine
+ IEEE 802.3x voo reguleerimine
Portide arv
24 10/100 Mbps porti, 2 10/100/1000BASE-T-porti, 2 10/100/1000BASE-T/SFP-liitporti
Täis-/pooldupleksedastus
+ Täis-/pooldupleksedastus kiiruste 10/100 Mbps korral
+ Täisdupleksedastus gigabitise kiiruse korral
Meedialiidese vahetus
Automaatne MDI/MDIX-ühenduse kohandamine kõigi keerdpaar- (bifilaar-) kaabliga portide puhul
Jõudlus
Kommutatsiooni jõudlus
12,8 Gbps
Edastusmeetod
Vahehoidega edastus
MAC-aadresside tabel
8 K mahus sissekandeid seadme kohta
MAC-aadresside värskendamine
kuni 256 staatilist MAC-sissekannet
Luba/blokeeri MAC-aadresside automaatne tuvastamine
Kuni 64-baidiste pakettide edastamise kiirus
9,5 Mpps
RAM-i puhver
512 KB seadme kohta
PoE Standard
802.3af, 802.3at
PoE pordid
Port 1-4 kuni 15.4 või 30W pordi kohta
Port 5-24 kuni 15.4W pordi kohta
PoE Poer Budget
193W
Tarkvara omadused
L2 taseme funktsioonid
+ MAC-aadresside tabel: maht 8 K
+ Voo reguleerimine
  - 802.3x voo reguleerimine
  - Head-of-line Blocking Preventioni funktsioon
+ IGMP-jälgimine
  - IGMP-jälgimine v1/v2
  - toetab 256 IGMP-rühma
  - toetab vähemalt 64 staatilist multiedastuse aadressi
  - IGMP VLAN-i kohta
  - toetab IGMP-jälgimise päringufunktsiooni
+ Genereeriva puu protokoll
  - 802.1D STP
  - 802.1w RSTP
+ Loopback Detection
+ 802.3ad linkide kuhjamine
  - kuni 8 rühma seadme kohta / kuni 8 porti rühma kohta
+ Pordi peegeldamine
  - One-to-One (ühelt ainsalt pordilt teisele)
  - Many-to-One (paljudelt portidelt ühele ainsale)
  - Tx/Rx/mõlemad
+ Kaabli diagnostika
+ Konfigureeritav Auto-MDI/MDIX
+ Multiedastuse filtreerimine*
  - edastab kõik registreerimata rühmad
  - filtreerib kõik registreerimata rühmad
VLAN
+ 802.1Q
+ VLAN-rühm
  - kuni 256 staatilist VLAN-rühma
  - kuni 4094 VID-d
+ Haldus-VLAN
+ Asümmeetriline VLAN
+ Auto-Voice VLAN
  - kuni 10 kasutaja määratletud OUI-d
  - kuni 8 vaike-OUI-d
Garanteeritud läbilaskevõime (QoS)
+ 802.1p QoS
+ 4 järjekorda pordi kohta
+ Järjekordade käsitlemine
  - vahemik
  - Weighted Round Robin (WRR)
  - CoS-põhine
  - 802.1p prioriteetjärjekorrad
+ DSCP
  - ribalaiuse kontroll
  - pordipõhine (sisenev/väljuv, minimaalne detailsus 64Kb/s)
Pääsuloend (ACL)
+ kuni 50 profiili
+ kuni 240 reeglit, mida profiilid kasutavad
+ ACL-i põhine
  - MAC-aadress
  - IPv4-aadress (ICMP/IGMP/TCP/UDP)
  - VLAN-i ID
  - 802.1p prioriteet
  - DSCP
+ ACL-tegevused
  - lubamine
  - blokeerimine
Turvalisus
+ 802.1X
+ Pordi turvalisus
  - toetab kuni 64 MAC-aadressi pordi kohta
+ Levi-, multi- ja üksikedastuse tormi reguleerimine
+ staatiline MAC
+ D-Linki Safeguard Engine
+ DHCP Server Screening*
+ ARP Spoofing Prevention*
  - kuni 64 sisendit
+ SSL*
  - toetab versioone v1/v2/v3
  - toetab IPv4
MIB
+ 1213 MIB II
+ 1493 Bridge MIB
+ 1907 SNMP v2 MIB
+ 1215 Trap Convention MIB
+ 2233 Interface Group MIB
+ D-Link Private MIB
RFC standardid
+ RFC 768 UDP
+ RFC 791 IP
+ RFC 792 ICMP
+ RFC 793 TCP
+ RFC 826 ARP
+ RFC 854 Telnetiserver
+ RFC 855 Telnetiserver
+ RFC 856 Telneti binaaredastus
+ RFC 858 Telnetiserver
+ RFC 896 ummikukontroll TCP/IP-võrgus
+ RFC 903 aadresside teisendamise protokoll RARP
+ RFC 951 BootP Client
+ RFC 1155 MIB
+ RFC 1157 SNMP v1
+ RFC 1191 maksimaalse ülekandeühiku (MTU) kindlakstegemine
+ RFC 1212 lühike haldusinfobaasi (MIB) määrang
+ RFC 1213 MIB II, IF MIB
+ RFC 1215 lõksud (traps), mida kasutada koos SNMP-ga
+ RFC 1239 standardne MIB
+ RFC 1350 TFTP
+ RFC 1493 Bridge MIB
+ RFC 1519 CIDR
+ RFC 1945 HTTP/1.0
+ RFC 2131 DHCP
+ RFC 2132 DHCP võimalused ja BOOTP Vendor Extensions
+ RFC 2138 RADIUS-e autentimine
+ RFC 2233 liides MIB
+ RFC 2578 haldusinfo struktuur, 2. versioon (SMIv2)
+ RFC 2647 802.1p
+ RFC 3416 SNMP
+ RFC 3417 SNMP
Haldus
+ veebipõhine GUI
+ Telneti kaudu toimiv kompaktne CLI
+ Telnetiserver
+ TFTP Client
+ SNMP
  - toetab versioone v1/v2/v3*
+ SNMP Trap (vigade ilmnemise korral kasutatav rakendus)
+ Trap-rakendus SmartConsole’i utiliidi jaoks
+ Süsteemi logifail
  - kuni 500 sissekannet
  - toetab IPv4 logiserverit
+ BootP/DHCP Client
+ Ajaseaded
  - lihtne võrguaja protokoll SNTP
Füüsilised parameetrid
Vahelduvvoolu sisend
100 kuni 240 V AC 50/60 Hz sisemine universaalne toiteallikas
Maksimaalne energiatarve
254 W (PoE sisselülitatud)
26.4 W (PoE väljalülitatud)
Akustika
53.9 dBA
Soojusenergia hajumine
866,65 BTU/h
Töötemperatuur
0 kuni 40 ˚C
Hoiustamistemperatuur
–10 kuni 70 ˚C
Töökeskkonna niiskusesisaldus
10% kuni 95%, mittekondenseeruv
Hoiustamiskeskkonna niiskusesisaldus
5% kuni 95%, mittekondenseeruv
Mõõdud
+ 440 mm x 250 mm x 44mm
+ 19-tolline standardne püstikmontaaži laius, kõrgus 1U
Diagnostilised valgusdioodid (LED)
+ Võimsus (seadme kohta)
+ Link/Aktiivsus/Kiirus (10/100/1000 Mbps pordi kohta)
+ Link/Aktiivsus/Kiirus (10/100 Mbps pordi kohta)
+ Link/Aktiivsus/Kiirus (SFP-pordi kohta)
Emissioon (EMI)
+ FCC A-klass
+ CE A-klass
+ VCCI A-klass
+ C-Tick
Keskmine tõrketu töövältus (MTBF)
197,343 h
Turvalisus
cUL, LVD
Sertifikaadid
Sidustooted
Pildid
DES-1210-28P/C
Tagantvaade
Paremvaade
Eestvaade
DES-1210-28P/B
Eestvaade
Tagantvaade
Eestvaade
Failid
Vaadake samuti
