Kiirotsing
Toote omadused:
10GB L2/L3 lüliti, 24 fikseeritud SFP+ 10G porti
Põhiomadused:
Liides
24 fikseeritud 10GB porti, laiendusmooduli lisamisvõimalusega
Konsooliport
RJ-45 out-of-band juhtimiseks
Juhtimisport
10/100/1000 Base-T RJ-45 out-of-band juhtimiseks
SD-kaardipesa
1
Jõudlus
• Switching capacity : 960 Gbps
• Max. Forwarding Rate: 595.2 Mpps
• Packet Buffer Memory: 9 МB
• MAC Address Table: 128K
Stackability
• Virtual Stacking/Clustering of up to 32 Units*
  - Supports D-Link Single IP Management
L2 Features
• ƒMAC Address Table
  - 128K entries
• Flow Control
  - 802.3x Flow Control when Full Duple
  - Back Pressure when Half Duplex
  - HOL Blocking Prevention
• Spanning Tree Protocol
  - 802.1D STP
  - 802.1w RSTP
  - 802.1s MSTP
  - Support Root Restriction
• Loopback Diagnostics*
• 802.1AX Link Aggregation
  - Max. 16 groups per device, 12 ports per group
• ERPS*  (Ethernet Ring Protection Switching)
• Port Mirroring
  - Supports One-to-One, Many-to-One
  - Supports Mirroring for Tx/Rx/Both
  - Supports 4 mirroring groups
• Flow Mirroring
  - Supports One-to-One,Many-to-One
  - Supports Mirroring for Rx
• Jumbo Frame
  - Up to 12,000 bytes
L2 Multicast Features
• IGMP Snooping
  - IGMP v1/v2/v3 Snooping
  - Supports 4K IGMP groups
  - Supports 1K static multicast addresses
  - IGMP per VLAN
• L2 Multicast Filtering
  - Forwards all groups
  - Forwards all unregistered groups
  - Filters all unregistered groups
ƒ• MLD Snooping*
  - MLD v1/v2 Snooping
  - Support 4K groups
  - Host-based MLD Snooping Fast Leave
VLAN
ƒ 802.1Q
ƒ 802.1v
ƒ Double VLAN (Q-in-Q)
  - Port-based Q-in-Q
  - Selective Q-in-Q
ƒ Port-based VLAN
 ƒMAC-based VLAN
ƒ Subnet-based VLAN
ƒ Private VLAN2
ƒ VLAN Group
  - Max. 4K static VLAN groups
  - Max. 4094 VIDs
ƒ GVRP
  - Up to 4K dynamic VLANs
QoS (Quality of Service)
ƒ 802.1p Quality of Service
ƒ 8 queues per port
ƒ Queue Handling
  - Strict
  - Weighted Round Robin (WRR)
  - Strict + WRR
  - Round Robin (RR)
  - Weighted Elastic Round Robin (WERR)
ƒ CoS based on
  - 802.1p Priority Queues
  - DSCP
  - IP address
  - MAC address
  - VLAN
  - IPv6 Traffic Class
  - IPv6 flow label
  - TCP/UDP port
ƒ Bandwidth Control
  - Port-based (Ingress/Egress, min. granularity 8 Kb/s)
  - Flow-based (Ingress/Egress, min.granularity 8 Kb/s)
  - Per queue bandwidth control (min. granularity 8 Kb/s)
ƒ Three Color Marker
  - trTCM
  - srTCM
ƒ Congestion Control
  - WRED
ƒ Support for following actions:
  - Remark 802.1p priority tag
  - Remark TOS/DSCP tag
  - Bandwidth Control
  - Committed Information Rate (CIR)
L3 Features (SI version)
 ARP
  - 512 Static ARP
  - Supports Gratuitous ARP*
ƒ IP Interface
  - Supports 256 interfaces
  ƒ Loopback Interface*
L3 Routing (SI version)
ƒ Default Routing
ƒ Static Routing
  - Max. 1K IPv4 entries
  - Max. 512 IPv6 entries2
  - Support route distribution
  - Support secondary route
  - Support Equal Cost/Weighted Cost multi-path route
Access Control List (ACL)
ƒ ƒMax. ACL entries:
  - 1792 ingress ACL rule
  - 1K egress ACL rules
  - 1K VLAN ACL rules
ƒ Time-based ACL
ƒ ACL based on:
  - 802.1p priority
  - VLAN
  - MAC address
  - Ether type
  - IP address
  - DSCP
  - Protocol type
  - TCP/UDP port number
  - IPv6 flow label
Security
ƒ Port Security
  - Supports up to 12K MAC addresses per port/system
ƒ Broadcast/Multicast/Unicast Storm Control
ƒ D-Link Safeguard Engine*
ƒ DHCP Server Screening*
ƒ IP-MAC-Port Binding*
  - ARP inspection
  - IP inspection
  - DHCP Snooping
ƒ ARP Spoofing Prevention*
  - Max. 64 entries
  ƒ Traffic Segmentation
ƒ SSL*
  - Supports v1/v2/v3
  - Supports IPv4/v6 access
  ƒ SSH
  ƒ BPDU Attack Prevention
  ƒ DOS Attack Prevention
AAA
ƒ 802.1X Authentication
  - Supports Port-based access contro
  - Supports Host-based access contro
  - Dynamic VLAN Assignment
  - Identity-driven Policy  (VLAN/ACL/QoS) Assignment
ƒ ƒWeb-based Access Control (WAC)*
ƒ ƒMAC-based Access Control (MAC)*
ƒ Guest VLAN
MIB & RFC Standards
ƒ RFC1213 MIB II
ƒƒ RFC1907 SNMP v2 MIB
ƒƒ RFC5519 IGMP v3 MIB
ƒƒ RFC1724 RIP v2 MIB
ƒƒ RFC2021 RMONv2 MIB
ƒƒ RFC1643, RFC2358, RFC2665 Ether-like MIB
ƒƒ RFC2668 802.3 MAU MIB
ƒƒ RFC2674 802.1p MIB
ƒƒ RFC2618 RADIUS Authentication Client MIB
ƒƒ RFC2096 IP Forwarding Table MIB
ƒƒ RFC2932 IPv4 Multicast Routing MIB
ƒƒ RFC2934 PIM MIB for IPv4
ƒƒ RFC2620 RADIUS Accounting Client MIB
ƒƒ RFC2925 Trace Out MIB
ƒƒ RFC2925 Ping MIB
ƒƒ RFC1850 OSPF MIB
ƒƒ Private MIB
ƒƒ RFC1112, RFC2236, RFC3376, RFC4541 IGMP Snooping
ƒƒ RFC4363 802.1v
ƒƒ RFC2338 VRRP
ƒƒ RFC1058, RFC1388, RFC1723, RFC2453, RFC2080 RIP
ƒƒ RFC1370, RFC1765, RFC2328, RFC2740, RFC3101 makes RFC1587 obsolete, RFC2328 makes RFC1583, RFC2178 OSPF v2,v3
ƒƒ RFC1771, RFC1997, RFC2439, RFC2796, RFC2842, RFC2918 BGP
ƒƒ RFC3973 PIM-DM
ƒ RFC5059 PIM-SM
ƒƒ RFC3569, RFC4601, RFC4608, RFC4607, RFC4604 PIM SSM
ƒƒ RFC3376 IGMP
ƒƒ RFC2475 Priority Queue Mapping
ƒƒ RFC2475, RFC2598 Class of Service (CoS)
ƒƒ RFC2597, RFC2598 QoS Flow Actions
ƒƒ RFC2697, RFC2698 Three Color Marker
ƒƒ RFC2093, RFC2904, RFC2095, RFC2906 AAA
ƒƒ RFC1321, RFC2144, RFC2313, RFC2420, RFC2841, RFC3394 Encryption
ƒƒ RFC2289 One-Time
ƒƒ RFC3580 802.1X
ƒƒ RFC2866 RADIUS Accounting
ƒ RFC2138, RFC2139, RFC2865, RFC2618 RADIUS Author. for Management Access
ƒƒ RFC1492 TACACS+ Auth. for Management Access
Füüsilised parameetrid
Toide:
100 - 240 V, 50/60 Hz
Kuumuse hajutamine:
Maksimaalne: 398.29 BTU/h
Ooterežiimil: 300.76 BTU/h
Mõõdud:
440 x 506 x 44 mm
Temperatuurid:
Töö: 0º ÷ 45º C
Säilitamis: -40º ÷ 70º C
Niiskus:
Tööniiskus: 0% ÷ 95%, ilma kondensaadita
Säilitusniiskus: 0% ÷ 95%, ilma kondensaadita
Indikaatorid:
Seadme kohta: Power 1, Power 2, Fan 1, Fan 2, Fan 3, Console, MGMT, SD Card, Stacking ID
SFP+ port: Link/Activity/Speed
Sertifikaadid:
Turvalisus: CB, cUL
FCC, CE, C-Tick, IC, VCCI, BSMI
* Need funktsioonid lisanduvad järgmistes versioonides
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
